![]() | Home > Technical (L322) > Limp Mode - Manifold pressure |
gilesharrison Member Since: 04 Aug 2018 Location: Cumbria Posts: 163 ![]() ![]() ![]() |
David,
Here's some photos if it helps anyone:
Rich_Allen Member Since: 05 Jan 2015 Location: Rutland Posts: 80 ![]() ![]() ![]() |
I had the same, seems to becoming more regular now...
I've got some JB Weld and I'm going to have a go at it when I get the chance. I know this will probably only be temporary but I'll see how it goes.
JST Member Since: 12 Dec 2013 Location: Somerset Posts: 502 ![]() ![]() ![]() |
Plastic weld it? Soldering iron and add material? Cheers
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2650 ![]() ![]() |
Likely to be too thin to plastic weld, ending-up with a hole instead of a crack. |
My plan is the clean the area up, roughen with and paper and degrease with alcohol. I'm going to seal/ overlay the crack with JB Weld reinforced epoxy.
try some CT1 if that doest work then and its too thin to weld. Cheers
Ok. So at the weeken, I attacked my intake manifold crack. Dirt and soot removed with WD40, the electrical contact cleaner to degrease. JB Weld applied liberally over the crack. Left for 24h to cure.
Grofus Member Since: 24 Mar 2017 Location: Co Clare Posts: 577 ![]() ![]() ![]() |
The best thing to "cold" weld plastic is liquid and powder nail acrylic. My other arf is a nail tech and I tried her nail stuff on some cracked motorbike fairings with great results. Since then any broken plastic bits get the treatment its stronger than original when done.
leusfx Member Since: 24 Jul 2018 Location: prague Posts: 25 ![]() |
Exactly the same crack has appeared on my valve cover at about 240.000 km. The sooty mess around the fuel rail and one of the injector fuel delivery pipes as per pictures above.
My JB Weld repair lasted about 2 weeks then the fault returned and it started going in to limp mode again.
cass Member Since: 12 Oct 2011 Location: northumberland Posts: 756 ![]() ![]() |
My repair lasted about 2K miles. Consensus seems to be that replacement is the only real solution |
Replacement is not option for me just yet as it is a big job.
