Home > Technical (L322) > Limp Mode - Manifold pressure
Page 4 of 5 <12345>
cass
Good luck with the fix - I was in contact with someone else who fixed his with Sikaflex marine and it lasted about a year, possibly due to being a bit more flexible?
Much as I moan about LR quality and reliability and as someone who's wallet got a kick because of this problem, I can't agree that it should be a recall. Mine lasted 12 years and 144K miles before it failed which looks like the norm - i'd be more than happy if I thought all other LR components lasted that long!
Post #539181 2nd Jan 2020 2:16pm
leusfx
Thanks gilesharrison and cass for information.
After some research I believe the only long term solution would be a true fusion weld. It is unlikely that adhesive bond can hold over long time with high pressure air behind it.
I conclude that the air intake manifold (valve cover also call rocker or cam cover) is made from type glass - reinforced version of nylon (PA). The melting point of glass reinforced nylon is 269 degrees Celsius which is much more than other plastics (PE, PET, PC, PPE etc.) I will get some powerful plastic welder with precision set up and attack the crack this way:
1. Clean area
2. Grind out a v-groove down the crack in the manifold with heat gun bit.
3. Weld the crack with nylon (PA) welding rod to patch the crack.
It would be ideal to attack also the backside of the crack but it would need to remove the manifold and in such case better to bite a bullet and replace it.
Post #539296 3rd Jan 2020 12:35pm
gilesharrison
United Kingdom 2008 Range Rover Vogue TDV8 Stornoway Grey
Wow. Good luck. I don't know anything about plastic welding but you definitely do.
Incidentally, the manifold replacement is not as big a job as suggested. The air con doesn't need de-gassing, and the engine does not need to be lifted. The rear injector can be removed by splitting it below the solenoid. Don't get me wrong, it's fiddly and time consuming but that's all. I could probably do it in about 6h (second time around)!
Post #539781 7th Jan 2020 10:50pm
leusfx
Thanks.
I'd like to share my solution to the issue. Eventually, I used Leister Triac ST heater gun with PA (nylon) settings and PA 6.6 welding rod. I did not have previous experience welding plastics but basically it is the same like any other welding. The gun can do really great job (AT version is better) with all sort of plastics but most importantly PA. My workshop manual says to de-gas and raise the engine up. RR is LHD, although I agree degas could be avoided. I did not know about the trick with the rear injector.
I will let you know how it goes as welding was success so far.
Post #540520 13th Jan 2020 11:46pm
gilesharrison
Good effort. I hope it lasts well.
Post #540533 14th Jan 2020 7:49am
cass
I wish I’d thought of that - the welder costs less than a new manifold never mind the labour involved.
Could be a canny sideline for an independent mechanic!
Post #540545 14th Jan 2020 10:43am
Andy
This is the exact same fault I've got. I've sprayed soapy water on the manifolds but I don't see any bubbling.
What really puzzles me is the infrequency that it faults apart from one particular location. If I leave work, I turn left onto an estate. For the first couple of months of ownership, it would always fault in the same place on that particular stretch of road, no matter how I drove it. More recently it doesn't do it at all, save for the very rare occasion.
I lived at the top of a big hill and it used to fault around 3/4 of the way up. Again, whether heavy footed or not. It's been two weeks now and no faults. When it does fault, it will fault every day for a week or so. It even faulted as I pulled off the driveway with very little acceleration. Yet other times, I can really push it and it won't fault.
I bought this car to replace my ageing TD6 and to tow a twin axle caravan. I'm frightened to tow it as it faulted a lot with the van on the back and one heart stopping moment last year, it almost came to a standstill on a steep hill. Foot flat to the floor and doing 10mph with traffic queueing behind us!
I have had a smoke test but it only detected a hole in the air box to turbo plastic trunking, which I replaced. Didn't cure the fault though.
I have the IID tool. How do I test the resistance of the MAP sensors? 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #540589 14th Jan 2020 7:52pm
gilesharrison
Swap the MAP sensors over and see if the fault remains on the same side on the engine.
Post #540624 14th Jan 2020 10:51pm
Andy
I’ve done that. Also replaced the top hoses with silicone even though there were no splits 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #540625 14th Jan 2020 10:53pm
gilesharrison
When I had my manifold crack, the error regularly used to happen up one certain hill. However, other times it seemed temperature dependant. Like when it was cold, it was less likely to give the error. Hot weather, or when the engine was hot, seemed to happen more.
Did you just change one of the manifolds?
Post #540635 15th Jan 2020 7:57am
leusfx
What is your trouble code when Limp mode happens?
Is it P023d-22 -
(Manifold absolute preassure - turbocharger/supercarger boost senzor A correlation - general signal failure.)?
This is most often a wiring issue or an air leak.
Check:
Intake air system fault (cracked manifold, turbo intercooler houses...)
Turbocharger mechanical failure
Intake air temperature sensor failure
Mass air flow sensor failure
Manifold absolute pressure and temperature sensor failure
Exhaust gas recirculation sensor failure
Turbocharger actuator position sensor failure
Post #540662 15th Jan 2020 12:19pm
Andy
Yes that’s the fault code.
I’ve swapped the MAP sensors and it’s still Bank A.
The top hoses have been replaced with silicone as a precaution.
The actuators seem ok but I’ve got nothing to compare them to.
EGRs have been mechanically and digitally removed.
I can’t see the lower hoses to check. I need a couple of dry days so I can get out on to the drive and strip it down.
I have thought wiring in the past and I hope in some ways it is that. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #540663 15th Jan 2020 12:27pm
leusfx
Rule out faulty turbo actuator with your IIDtool.
Select Live values and compare Command boost actuator control banks 1/2 with Boost pressure actuator banks 1/2 and create log when driving.
Try monitor the turbocharger actuator position and command the actuator to 5% PWM, then 95% PWM in 5% steps (unfortunately this function is not always working (not working on my 2008TDV8; IIDtool). Check the results. There should be a smooth curve between the minimum and maximum values. If not, install a new turbocharger.
Post #540687 15th Jan 2020 4:31pm
Andy
How do I increase by 5% whilst driving? Once it’s data logging it can’t be changed can it? 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #540730 16th Jan 2020 7:44am
leusfx
That's supposed to be done when idling.
Post #540756 16th Jan 2020 12:48pm
Page 4 of 5 <12345>
