Home > Technical (L322) > Limp Mode - Manifold pressure |
gilesharrison Member Since: 04 Aug 2018 Location: Cumbria Posts: 163 |
That's certainly one way of replacing turbos! |
3rd Oct 2018 6:05pm |
DMRR Member Since: 14 Apr 2010 Location: Northamptonshire Posts: 2027 |
Sure is
3rd Oct 2018 7:46pm |
Thanks for the reply Nick.
5th Oct 2018 2:52pm |
I would concur as the nasty clonking/rattling sound (combined with burning oil!) on my failed one with the same code is the drivers side..... Land Rover Addict
5th Oct 2018 3:05pm |
Thanks DMRR |
5th Oct 2018 10:15pm |
Nick591 Member Since: 04 May 2017 Location: Seaton Dalaval Posts: 193 |
Yes - the manual is pretty unclear but Bank 1 is Bank A which is the drivers side. It took me a while to check that out when I first started having these problems but it is definitely right. Previously a 2008MY Tonga Green Vogue SE 3.6 TDV8 |
6th Oct 2018 9:58am |
Ok, so I've swapped my two MAP sensors over. The fault remains on Sensor A.
10th Oct 2018 8:39pm |
chefkenmore Member Since: 11 Jan 2015 Location: Fearnan perthshire Posts: 748 |
Smoke test is the way forward, I’ve also replaced both my turbos! Wouldn’t just do one,as the other wouldn’t be long in following! 2014 vogue se |
10th Oct 2018 9:00pm |
Smoke test - I hope it's something simple for you and not terminal like mine Land Rover Addict
10th Oct 2018 9:32pm |
Hi Giles. I wouldn't rush to blame the turbo just yet but certainly get a smoke test to eliminate split hoses etc. There's no certainty that our two faults have the same cause but they are remarkably similar. Read the below which I have posted on my original thread. Do you have an IID Tool or access to a code reader? Worth checking if you are getting similar errors to me.
10th Oct 2018 9:45pm |
Thanks for the replies guys. I'll book it in for a smoke test.
10th Oct 2018 10:03pm |
Just a thought.
13th Oct 2018 6:09pm |
Giles,
13th Oct 2018 8:30pm |
Thanks David.
13th Oct 2018 9:21pm |
