Home > Maintenance & Mods (L322) > 7 pin to 13 pin tow electrics conversion
Andy
AJGalaxy2012 wrote:
Try this, my electrics had been on fire!
http://www.fullfatrr.com/forum/topic48429.html
j
I’ve just realised that was a thread I’d started! I forgot about that one!
I assume the pink/blue on yours is the pink on mine. Yours is 2012 and mines 2002 so different wiring I’m guessing
Post #491446 8th Oct 2018 4:27pm
rjff
Andy
Having got to the point of 8 wires connected, do the trailer lights work correctly, including the reversing lights of your trailer, if fitted?
If so then the remaining four wires should be two earths and two positive feeds. We can go on from there if the light check is good. Cheers
Richard
Gap IIDBT
Post #491447 8th Oct 2018 4:53pm
Andy
No idea. The caravan is 30 miles away! 😂
Post #491450 8th Oct 2018 5:00pm
rjff
Oh b Censored r Sad
If you leave now it will be about dark enough to see the results without any one else helping!!
Seriously, can't help on the colours as mine is a 2011, but PF Jones have some info on their website and a search for wiring on their site and others you can think of on your year should help. If not the worst would be to buy a new loom from a supplier like Jones (expensive) or elsewhere for your model year.
If you have the lights working properly when you test as fitted now, then I think the remaining four wires are 2 live and 2 earth.
You also seem to have two threads running at the moment, would it be better to direct our replies to one? Cheers
Richard
Gap IIDBT
Post #491455 8th Oct 2018 5:20pm
Andy
Yes I’d forgotten about the other thread!
Probably best to reply to that other one.
Post #491457 8th Oct 2018 5:24pm
IanV8
Scotland 2011 Range Rover Vogue SE TDV8 Santorini Black
northernmonkeyjones wrote:
for the tin tent there is nothing which needs a perm feed from the car afaik. Fridge and charger will be 12v switched. so if that is all you have.......
Caravans need a permanent live for their ATC or IDC, stability control.
Ian
Post #491545 9th Oct 2018 8:08am
good point. Suppose the depends if you have atc though. There is nothing that can't be fixed with a hammer😜😜
Post #491594 9th Oct 2018 3:10pm
DrRob
I have single 7 pin and want to convert to single 13 pin.
I’m guessing I need to buy the complete kit ie. wiring and the module ?
I assume I can’t just replace the wiring and keep the 7 pin module?
Hope that makes sense
Rob Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #491604 9th Oct 2018 4:51pm
AJGalaxy2012
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Bonatti Grey
Have a look in the boot nearside of the spare wheel well and see if you have the connector there fully populated.
This is the connector BMW i3 Electric Car
2012 Full Fat RR 4.4 TDV8 (now gone)
2006 VW Touareg 3.0 TDi V6
Post #491607 9th Oct 2018 5:23pm
DrRob
Will do and report back. I assume the other end of that is the module? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #491617 9th Oct 2018 6:48pm
AJGalaxy2012
I assume so, I have all the colour codes sorted on that connector so you can wire either 2 x 7 or 13 pin. BMW i3 Electric Car
Post #491620 9th Oct 2018 6:56pm
Andy
All sorted. Pink was the permanent live. All wired up and tested.
Post #492481 15th Oct 2018 11:19pm
DrRob
Ducky Dan has quoted me for a Genuine one which is tempting Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #492595 16th Oct 2018 7:40pm
