Home > Maintenance & Mods (L322) > 7 pin to 13 pin tow electrics conversion |
Andy Member Since: 23 Feb 2009 Location: Shropshire Posts: 2938 |
I’ve just realised that was a thread I’d started! I forgot about that one! I assume the pink/blue on yours is the pink on mine. Yours is 2012 and mines 2002 so different wiring I’m guessing |
8th Oct 2018 4:27pm |
No idea. The caravan is 30 miles away! 😂 |
8th Oct 2018 5:00pm |
rjff Member Since: 28 Oct 2017 Location: Cambridgeshire Posts: 1196 |
Oh b r
8th Oct 2018 5:20pm |
Yes I’d forgotten about the other thread!
8th Oct 2018 5:24pm |
IanV8 Member Since: 14 Jan 2010 Location: Dunfermline Posts: 502 |
Caravans need a permanent live for their ATC or IDC, stability control. Ian |
9th Oct 2018 8:08am |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8508 |
good point. Suppose the depends if you have atc though. There is nothing that can't be fixed with a hammer😜😜
9th Oct 2018 3:10pm |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4302 |
I have single 7 pin and want to convert to single 13 pin.
9th Oct 2018 4:51pm |
AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1464 |
Have a look in the boot nearside of the spare wheel well and see if you have the connector there fully populated.
9th Oct 2018 5:23pm |
Will do and report back. I assume the other end of that is the module? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
9th Oct 2018 6:48pm |
I assume so, I have all the colour codes sorted on that connector so you can wire either 2 x 7 or 13 pin. BMW i3 Electric Car
9th Oct 2018 6:56pm |
All sorted. Pink was the permanent live. All wired up and tested. |
15th Oct 2018 11:19pm |
Ducky Dan has quoted me for a Genuine one which is tempting Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
16th Oct 2018 7:40pm |
