Home > Technical (L322) > Height calibration using IID tool |
Andy Member Since: 23 Feb 2009 Location: Shropshire Posts: 2938 |
Does anyone have the standard settings for the height calibration in the IID tool please? |
7th Oct 2018 11:44am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35271 |
7th Oct 2018 11:51am |
Thanks Stan
7th Oct 2018 9:19pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6408 |
For calibration with the iiDTool measure from centre of hub to bottom of wing (metal not plastic inner wing)
8th Oct 2018 7:43am |
So in my menu, I go to calibration > manual calibration then change the numbers to whatever the current measurement is, or what’s on your chart above?
8th Oct 2018 11:21am |
if the front rises on its own then dont mess with the height settings..you have a problem that needs sorting.. |
8th Oct 2018 11:34am |
See here
8th Oct 2018 11:37am |
It’s doing my head in.
8th Oct 2018 11:51am |
i guess it could be the height sensor which is faulty..have had any work on the tyres/wheels recently.. |
8th Oct 2018 11:54am |
I replaced the r/h sensor and the fault was still there (articulation relay). I went to change the L/H sensor and noticed a break in one of the sensor wires so I soldered/heatshrunk it and the fault cleared but it still raises with no faults. |
8th Oct 2018 12:15pm |
After clearing faults have any returned (faults) ?
8th Oct 2018 12:59pm |
kooky_guy Member Since: 25 Nov 2011 Location: Sandhurst, Berkshire Posts: 385 |
Anyone know the heights for 21 inch wheels? 2010 4.4 TDV8 Vogue SE |
10th Oct 2018 6:55am |
Flashman Member Since: 05 Jun 2011 Location: Windsor & Brentwood Posts: 1228 |
Not sure if it is the same for the newer models but on my 2005 model year Td6 when calibrating the heights you have the ability to adjust each corner by a figure of up to 200. This figure is not an actual measurement but purely an adjustment range from whatever the current setting is.
10th Oct 2018 7:38am |
@ kooky_guy
10th Oct 2018 4:57pm |
