![]() | Home > Technical (L322) > Height calibration using IID tool |
Andy Member Since: 23 Feb 2009 Location: Shropshire Posts: 2944 ![]() ![]() ![]() |
Does anyone have the standard settings for the height calibration in the IID tool please? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35487 ![]() ![]() |
Thanks Stan
For calibration with the iiDTool measure from centre of hub to bottom of wing (metal not plastic inner wing)
So in my menu, I go to calibration > manual calibration then change the numbers to whatever the current measurement is, or what’s on your chart above?
if the front rises on its own then dont mess with the height settings..you have a problem that needs sorting.. |
See here
It’s doing my head in.
i guess it could be the height sensor which is faulty..have had any work on the tyres/wheels recently.. |
I replaced the r/h sensor and the fault was still there (articulation relay). I went to change the L/H sensor and noticed a break in one of the sensor wires so I soldered/heatshrunk it and the fault cleared but it still raises with no faults. |
After clearing faults have any returned (faults) ?
kooky_guy Member Since: 25 Nov 2011 Location: Sandhurst, Berkshire Posts: 386 ![]() ![]() ![]() |
Anyone know the heights for 21 inch wheels? 2010 4.4 TDV8 Vogue SE |
Flashman Member Since: 05 Jun 2011 Location: Windsor & Brentwood Posts: 1228 ![]() ![]() ![]() |
Not sure if it is the same for the newer models but on my 2005 model year Td6 when calibrating the heights you have the ability to adjust each corner by a figure of up to 200. This figure is not an actual measurement but purely an adjustment range from whatever the current setting is.
@ kooky_guy
