Home > Technical (L322) > Height calibration using IID tool
jim4244
England 2005 Range Rover Vogue Td6 Zambezi Silver
I know that this is and old thread but as an IID sprog I just wanted to get peoples thoughts on the suspension height values I have recorded.
What do folk think of the below?
These were the heights that were set.
I changed them to the heights below.
Jim
Post #568408 30th Sep 2020 8:32am
jim4244
I take it that when the heights turn to amber they are outside the recommended limits?
Jim
Post #568433 30th Sep 2020 3:10pm
you do know that the fronts need to be a cm higher than the rears.... ... - .- -.
Post #568435 30th Sep 2020 3:17pm
qwerty
2016 Range Rover Autobiography SDV8 Carpathian Grey
Hi,
Those figures are not the heights, they are values for the sensors that you tie in to a measured height on each corner? You would never see equal values either side! I am guessing you have gone into manual calibration and changed the numbers without taking measurements? I would start by putting them back to the original values and then find some level ground and follow the guided calibration process. The four corner values will all be different. Take your time with the measurements and follow the steps carefully.
Enjoy your new ride.....
Post #568452 30th Sep 2020 5:50pm
qwerty
How did you get on?
Post #568789 3rd Oct 2020 3:18pm
