![]() | Home > Technical (L322) > Replaced discs, STILL got brake judder |
mpirie Member Since: 26 Jun 2012 Location: In the Highlands Posts: 907 ![]() ![]() ![]() |
Have you checked for a seized rear caliper?
Mulcher Member Since: 08 Aug 2016 Location: Shropshire Posts: 240 ![]() ![]() ![]() |
Thanks, I'll check for a hot wheel. Just so I completely understand, by "seized caliper" do you mean the brake pistons seized in the caliper bores? 2006MY 4.2 SC
Yes, it can either be the piston corroded into the bore of the caliper (most likely) or the caliper carrier corroded and stuck (less likely).
Mikeyjd Member Since: 14 Jun 2011 Location: Wrexham Posts: 543 ![]() ![]() ![]() |
It isn't always obvious which wheel/brake is juddering. I had a judder felt through the pedal when braking heavily. The car passed its MOT so I didn't get round to sorting it out for a while. Only when I wanted to PX the car did I decide to fix the problem.
Just as an update for the benefit of others, the fault was eventually tracked to the rear nearside brake disc. A piece of the disc’s braking surface about the size of 50p piece had broken away, sort of delaminated to a depth of 1 to 1.5 mm.
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6419 ![]() ![]() |
Thanks for rounding off with a solution |
Full Fattie Member Since: 10 Aug 2018 Location: Sunderland Posts: 245 ![]() ![]() ![]() |
I didn’t think rear discs would warp but they did on a previous car. If you have a manual handbrake you can test the tears by pulling it on slightly while driving to see if you can feel it. |
bembo449 Member Since: 26 Jul 2017 Location: lincolnshire Posts: 803 ![]() ![]() ![]() |
It always surprises me how such a big hunk of metal can be so sensitive to vibrations caused by things such as this |
