Home > Technical (L322) > Replaced discs, STILL got brake judder
Mulcher
England 2006 Range Rover Supercharged 4.2 SC V8 Zambezi Silver
To cure a brake judder problem on my 06MY 4.2 SC I had my warped front discs, and pads replaced (with LR parts) by my usual local garage (who is very good but not a specialist LR Indy).
They told me the new discs had improved matters a lot but hadn't completely eliminated the judder/vibration/noise which seems to be coming from the nearside front. I'm not feeling it through the brake pedal or steering, its felt and heard through floor/bulkhead. It's similar to brake judder but not as harsh and the quality of the noise is different – hard to explain.
They found a split bush on a suspension arm (I can't remember the exact name of the part) and suggested it was this that was causing movement under braking.
New part fitted but it has not cured the problem. Garage has tested:
    – run-out on discs,
    – swapped discs left to right to see if problem moved,
    – they have a brake tester with 4-wheel-drive mode which tests each wheel independently,
    – on-road brake testing at various speeds, plus braking whilst turning left & right.
The garage is baffled. I've searched through the forum but can't find anything closely similar.
Has anyone got any ideas or suggestions as to what the garage might try next?
Thanks. 2006MY 4.2 SC
BMW R1250 GSA Rallye TE
Triumph Tiger 1050 (sold)
1979 Pontiac Trans Am (sold)
Post #490852 3rd Oct 2018 7:20pm
mpirie
Have you checked for a seized rear caliper?
The normal signs are of juddering while braking and a very hot wheel on the side of the seized caliper.
Mike
Post #490854 3rd Oct 2018 7:24pm
Mulcher
Thanks, I'll check for a hot wheel. Just so I completely understand, by "seized caliper" do you mean the brake pistons seized in the caliper bores? 2006MY 4.2 SC
Post #490897 4th Oct 2018 8:21am
mpirie
Yes, it can either be the piston corroded into the bore of the caliper (most likely) or the caliper carrier corroded and stuck (less likely).
Mike
Post #490908 4th Oct 2018 9:52am
Mikeyjd
Wales 2003 Range Rover SE Td6 Zambezi Silver
It isn't always obvious which wheel/brake is juddering. I had a judder felt through the pedal when braking heavily. The car passed its MOT so I didn't get round to sorting it out for a while. Only when I wanted to PX the car did I decide to fix the problem.
From the general feel, I was convinced it was offside rear brake. I replaced both rear discs and pads... Still the same! So I bought a pair of discs and pads for the front. I fitted the front offside, and just for curiosity I decide to test the car before doing the nearside. Yep, still the same! I fitted the front nearside and problem solved.
So, in the end it was the opposite end and opposite side that was causing the issue. I will never assume anything with cars again. No longer FF owner but still interested. Present car Jaguar XE
Previous car Td6 SE
Previous LR- Disco 300TDi Auto
Post #490927 4th Oct 2018 1:08pm
Mulcher
Just as an update for the benefit of others, the fault was eventually tracked to the rear nearside brake disc. A piece of the disc’s braking surface about the size of 50p piece had broken away, sort of delaminated to a depth of 1 to 1.5 mm.
The garage had removed and examined the rear caliper and the outer surface of the disc looked in good condition with very little scoring or wear. However, they could only see the inside surface of the disc at the point revealed by the removed caliper because the rest of the inside surface is covered by the splash shield! What they could see of the disc gave no clue as to the true nature of the problem so they concluded it wasn’t the culprit.
After eliminating everything else they could think of the boss adopted a “this Censored is not going to beat me” attitude and did a complete strip down (of the brakes/hubs Very Happy ). As soon as the disc was completely removed they saw the problem.
So now I’ve got new discs and pads all round – problem solved.
For entertainment value I think I’ll revue the dashcam footage of their road testing to listen to all the swearing.
BTW multiple short-run brake tests will guzzle fuel like you wouldn’t believe – I’d reset the mpg just a few days before taking it to the garage and it was mid-17s, when I got it back it was showing 6.7 mpg! Shocked Thud Is this a record? 2006MY 4.2 SC
Post #491965 12th Oct 2018 11:52am
Thanks for rounding off with a solution Thumbs Up .
Post #491969 12th Oct 2018 1:03pm
Full Fattie
United Kingdom 2007 Range Rover Vogue SE 4.2 SC V8 Zambezi Silver
I didn’t think rear discs would warp but they did on a previous car. If you have a manual handbrake you can test the tears by pulling it on slightly while driving to see if you can feel it.
Post #492014 12th Oct 2018 7:10pm
bembo449
United Kingdom 2002 Range Rover Vogue Td6 Adriatic Blue
It always surprises me how such a big hunk of metal can be so sensitive to vibrations caused by things such as this Neutral Confused
I worked on 100s of vehicles where the discs and pads are shot but you wouldn't know by driving them
Post #492096 13th Oct 2018 12:01pm
