![]() | Home > Maintenance & Mods (L322) > The dredded oil cooler leak !!! |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4318 ![]() ![]() ![]() |
Are there 2 gaskets between the cooler and engine? Thanks ![]() 2025MY Defender D350 90 in Silicon Silver on coils 1974 Series 3 Lightweight = "Millie" Many, many other Landies over the years My preferred specialist: www.glenrands.co.uk -------------------------------------------------- |
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 ![]() ![]() ![]() |
Yes, Rob. |
Frans@Yamorna Member Since: 15 Apr 2017 Location: Tzaneen Posts: 147 ![]() ![]() ![]() |
160dmb Member Since: 16 Dec 2012 Location: Hertfordshire Posts: 455 ![]() ![]() ![]() |
Just to confirm I had the gaskets and O ring changed on my L322 about 6/12 months ago and that was it - job done, no more leaks and no damage to the cooler itself - it was actually the gaskets on mine but I did the O ring too because that seemed like the right thing to do.
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2561 ![]() ![]() ![]() |
I would leave changing gaskets until a leak is detected in case more suitable gaskets that withstand the heat from the EGR cooler become available unless other sealant will be used. Replacement gaskets are the same part number as the originals so will be the same material and therefore will also leak once they too go hard. |
EmiratesA380 Member Since: 14 Jan 2015 Location: england Posts: 352 ![]() ![]() ![]() |
So why did LR issue the TSB for the oil cooler gasket, make the gasket available as a spare part and add the procedure to the WSM? It seems to me that someone at the dealership stuffed-up causing the engine to be damaged so had to fix it. The task is a simple one but requires that the oil is not contaminated in the process. |
Maybe an apprentice didn't appreciate the care that an open, post-filter oil-way requires. Even the task of replacing an inlet manifold where the camshafts are exposed doesn't require the same care because the oil is pre-filter with only the oil pump exposed to damage. |
Who did it and how much? Gathering quotes for me and the forum ![]() 2025MY Defender D350 90 in Silicon Silver on coils 1974 Series 3 Lightweight = "Millie" Many, many other Landies over the years My preferred specialist: www.glenrands.co.uk -------------------------------------------------- |
John w Member Since: 14 Jan 2018 Location: Cranleigh, Surrey Posts: 439 ![]() ![]() ![]() |
I would love to know what the guy did in order to lunch the engine.
SinbadRose Member Since: 21 Aug 2017 Location: Merseyside Posts: 114 ![]() ![]() ![]() |
one of the guys i work with told me about the indy he uses, dropped in, as soon as i mentioned what i had been told, he laughed, popped the bonnet, took a look and said 1.5 hours and gaskets, end of. Booked in on first available slot.
Just received update from JLR workshop!!!!Bad news,it is the EGR cooler that cracked,not the oil cooler and the repair cost is much higher and that component is not covered by my extended policy ![]() ![]() |
