![]() | Home > Maintenance & Mods (L322) > Engine replacement - Range Rover 2011 4.4 TDV8 RESCUED |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3820 ![]() ![]() ![]() |
This place have been advertising bits from a 2011 44tdv8 they are breaking.
Mike. G reg 2.5VM Vogue Portofino red 1991- 1999 V reg 2.5td P38 Rioja red 1999- 2006 53 reg td6 Vogue Oslo blue 2006- 2015 11 reg 4.4 TdV8 Vogue SE. Baltic blue 2015- date. https://www.fullfatrr.com/forum/topic56162...tty+affair |
Salter121 Member Since: 20 Jun 2018 Location: Berkshire Posts: 128 ![]() ![]() ![]() |
Hi thanks; yes I spoke with them and they did have one; but I was a few days late as they have already sold it. thanks though. |
[quote="MJGH"]
Hi thanks; I searched the site but could not find it.... |
MJGH Member Since: 15 Jul 2018 Location: Essex Posts: 102 ![]() ![]() ![]() |
If you go to Market Place
Bushy30 Member Since: 03 Jun 2018 Location: Powys Posts: 1099 ![]() ![]() ![]() |
MJGH,
Thank you for enlightening me |
Finally tracked down complete exhaust system - take a look at the sad looking donor car
Pfazz Member Since: 07 Apr 2012 Location: Stalybridge, Cheshire. Posts: 507 ![]() ![]() |
A couple of cans of T cut should sort that out. Agueroooooooooo. 93-20
Thank god for the invention of eBay!
Might not seem like a lot of progress, but a long way from where it was.
Aug:
Sept:
MR GLOVER Member Since: 03 Jan 2015 Location: grimsby Posts: 605 ![]() ![]() ![]() |
looking good |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8750 ![]() ![]() ![]() |
It’s coming on that👍🏻 There is nothing that can't be fixed with a hammer😜😜
This has been a very long process indeed, but we are getting there.
Finally managed to get the right one; could not find a brand new one so had to go for a reconditioned unit; but turned up looking awesome.
And it continues.....
Replacement exhaust finally goes on... had to be chopped for transportation; but not an issue.
Now the pipes..... and pipes..... and more pipes!
Just as a note for anyone reading this now or in the future, the LHS Turbo from L405 will fit in L322, however, the RHS will not as it is a completely different unit. It may have been possible to fit it if I had of changed for a reverse set-up starter motor; because that is what seemed to be stopping it fitting; but not sure. The easiest option for me was to just go for the intended L322 turbo.
L405 RHS turbo that did not (just)
