![]() | Home > Technical (L322) > Intermittent ABS / HDC /Air Susp Bongs. |
PaulTyrer Member Since: 22 Jul 2013 Location: Devizes, Wiltshire Posts: 1259 ![]() ![]() ![]() |
Thanks, I did have a look at that and it seemed all ok, but if it ever stops raining I'll have another look! |
Matt Pearce Member Since: 10 Jan 2018 Location: Bedfordshire Posts: 25 ![]() ![]() ![]() |
Hey Paul, i dont know if you are still around , i have only just received this notification via email..
H,
As previously mentioned, you need to check your ABS sensors, reluctor rings, and wiring/connectors first .
UK Marine Member Since: 22 Jul 2016 Location: Durham, County Durham UK Posts: 830 ![]() ![]() ![]() |
You only send the module to be looked at NOT the hydraulic part, so no pipes have to be disconnected. From memory its just 4 screws and then you carefully pull the module away from the hydraulic unit. I swapped mine over for a good used unit and it solved my problems. ______________________________
Paul, Simon is right, its onlt six torx screws, but best to first remove the few bits directly in front of it before you try.. all in all its @bout 10 minutes, being careful not to drop the two right hand side lower torx into the abbys!
Matt,
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2218 ![]() ![]() ![]() |
I want to hate you for face lifting the ff and keeping the original smallest wheels with the fattest tyres on it should look stupid but it actually looks really good... Current stable: 2006 BMW M6 2007 4.2 V8 S/C FF Gone: 2002 4.4 V8 FF |
ohuntsman Member Since: 21 Mar 2016 Location: Surrey Posts: 337 ![]() ![]() ![]() |
Any joy at fixing this issue?
alfapat Member Since: 09 Apr 2017 Location: Elgin Posts: 349 ![]() ![]() ![]() |
Just take module off,, no pipes, get it checked , can still run car in default mode. |
Have a look at what goes down on my thread , D Day tomorrow with new Genuine sensors , but check the ste of tour abs rings first , every thing shuts down due to bad input with wheel speed sensors or rings , depending on how corroded they are. |
I have. I fitted one about two years ago. I used P.A.Soft 1.4 to code the secondhand module to my car, basically changing the stored VIN in the module to mine. The most important thing to do is to calibrate the steering angle sensor afterwards as it stores the information about where the wheels are pointing so that the ABS module can enable HDC. ![]() Simon ______________________________ Range Rover Classic 3.5 efi - Gone Range Rover Classic 3.9 efi - Gone Range Rover Classic 4.2 LSE - Sadly gone Land Rover 110 3.5 - Gone Range Rover P38a 4.0 SE - Pleased it's gone Range Rover P38a 2.5 DHSE - Just sold Range Rover L322 4.4 v8 Petrol - Current |
