![]() | Home > Technical (L322) > Intermittent ABS / HDC /Air Susp Bongs. |
PaulTyrer Member Since: 22 Jul 2013 Location: Devizes, Wiltshire Posts: 1259 ![]() ![]() ![]() |
Last year our RR spent some time in car hospital. Initially it was in a main LR dealer and was throwing some errors, this was put down to a faulty steering angle sensor on I think the steering column, which was replaced. The car was then in our local garage for a couple of weeks waiting for a new door lock.
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1351 ![]() ![]() |
get the codes read
Thanks.
Keith A Member Since: 25 Oct 2012 Location: Sherborne, Dorset Posts: 105 ![]() ![]() ![]() |
See the link below, this was the cause of my hdc/abs etc etc issue. No problems since fixing.
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2218 ![]() ![]() ![]() |
Or could be the steering sensor like mine Current stable:
Went out in the car at the weekend.
That is basically what was happening to mine. Some journeys fine, others straight away, or at random times. Current cars:
alfapat Member Since: 09 Apr 2017 Location: Elgin Posts: 349 ![]() ![]() ![]() |
I have the same , reading forums it may have to with a low battery.
zarnd Member Since: 22 May 2014 Location: Kent Posts: 459 ![]() ![]() ![]() |
I had similar and my suspension would lock so was not adjustable. I drilled a hole in the exhaust for the suspension compressor and all was well afterwards.
lounge_on_wheels Member Since: 10 Dec 2016 Location: in the great land of oz Posts: 269 ![]() ![]() ![]() |
Steering sensor cause my problems just like Danwilderspin said |
UK Marine Member Since: 22 Jul 2016 Location: Durham, County Durham UK Posts: 830 ![]() ![]() ![]() |
Mine was intermittent and only when it got hot, either driving or idling. It was the ABS module, the electrical bit not the other bit.
Matt Pearce Member Since: 10 Jan 2018 Location: Bedfordshire Posts: 25 ![]() ![]() ![]() |
Hey Paul, I have had
Our local mechanic ran some diagnostics this week, interestingly he couldn't get the ABS / HDC bongs to happen!
