Home > Technical (L322) > Heavy power steering. Servotronic valve? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35290 |
could be that or the BCU
17th Sep 2018 1:57pm |
ChrisJJ Member Since: 31 Aug 2018 Location: Redcar Posts: 39 |
Thanks Stan.
17th Sep 2018 2:44pm |
Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3142 |
Search BCU on here. there is lots of info. It also sometime/often ties up with one of the doors not unlocking. Easy job to change for new. 1 hr tops. |
17th Sep 2018 6:00pm |
Pawl Member Since: 07 Nov 2017 Location: West Midlands Posts: 689 |
That's unlikely to be the servotronic valve - it's effect is most at idle and reduces significantly at speed, but appears not to go to zero. Paul,
17th Sep 2018 6:12pm |
Isn't servotronic active all the time and dictates how much assistance to give based on speed? i.e less at speed gives more stability.
17th Sep 2018 7:17pm |
The Servotronic valve causes extra hydraulic assistance to be added over and above the steering rack base assistance.
17th Sep 2018 7:44pm |
Cheers Pawl.
17th Sep 2018 8:01pm |
Maybe it is the BCU then - providing the correct output at very slow speed, but incorrect output intermittently at slightly higher speeds.
17th Sep 2018 8:09pm |
Teaspoonasaurous Member Since: 08 Jul 2018 Location: Cambridge Posts: 73 |
I’m having the same issue. I checked codes and it said fuse b30 in BCU was gone. I’m going to investigate further on Sunday.
20th Sep 2018 7:38am |
Gonna get out there now with the computer and see if there's any codes.
20th Sep 2018 10:06am |
Ran diagnostic.
20th Sep 2018 10:49am |
You mentioned disconnecting the Servotronic valve in an earlier post. I forgot to say there's nothing to lose by trying that & seeing how the symptoms change - its all useful extra diagnostic info.
20th Sep 2018 10:50am |
I'll disconnect the servotronic now and see what happens.
20th Sep 2018 10:59am |
The BCU output is a Pulsed Width Modulated voltage & current - ie voltage that's be shut off & re-started at a varying frequency dependant on the vehicle speed.
20th Sep 2018 11:09am |
