![]() | Home > Technical (L322) > Heavy power steering. Servotronic valve? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35515 ![]() ![]() |
could be that or the BCU
ChrisJJ Member Since: 31 Aug 2018 Location: Redcar Posts: 39 ![]() ![]() ![]() |
Thanks Stan.
Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3199 ![]() ![]() |
Search BCU on here. there is lots of info. It also sometime/often ties up with one of the doors not unlocking. Easy job to change for new. 1 hr tops. |
Pawl Member Since: 07 Nov 2017 Location: West Midlands Posts: 698 ![]() ![]() ![]() |
That's unlikely to be the servotronic valve - it's effect is most at idle and reduces significantly at speed, but appears not to go to zero. Paul,
Isn't servotronic active all the time and dictates how much assistance to give based on speed? i.e less at speed gives more stability.
The Servotronic valve causes extra hydraulic assistance to be added over and above the steering rack base assistance.
Cheers Pawl.
Maybe it is the BCU then - providing the correct output at very slow speed, but incorrect output intermittently at slightly higher speeds.
Teaspoonasaurous Member Since: 08 Jul 2018 Location: Cambridge Posts: 73 ![]() ![]() ![]() |
I’m having the same issue. I checked codes and it said fuse b30 in BCU was gone. I’m going to investigate further on Sunday.
Gonna get out there now with the computer and see if there's any codes.
Ran diagnostic.
You mentioned disconnecting the Servotronic valve in an earlier post. I forgot to say there's nothing to lose by trying that & seeing how the symptoms change - its all useful extra diagnostic info.
I'll disconnect the servotronic now and see what happens.
The BCU output is a Pulsed Width Modulated voltage & current - ie voltage that's be shut off & re-started at a varying frequency dependant on the vehicle speed.
