Home > Maintenance & Mods (L322) > Silly question from a newbie....
TedwoodLawler
United Kingdom 2009 Range Rover Vogue SE TDV8 Santorini Black
I finally picked up my fatty today and, being of a more vertically challenged persuasion, have a hankering to fitting some side steps. On looking at the sills, the outer ones have a plastic covering. I know there was a pack offering some enhancement there, but not sure if this is it and whether it would affect fitting side steps. Any help gratefully received. Very Happy
Post #488839 13th Sep 2018 6:14pm
Rosco
United Kingdom 2013 Range Rover Autobiography SDV8 Baltic Blue
There are holes pre drilled on the chassis to take side steps, the plastic covering is irrelevant and stays put. Thumbs Up
Post #488841 13th Sep 2018 6:20pm
It is a sensible thing to do, saves trouble with the seat bolster and seat plastic surround which get worn and damaged with the "sliding off"
Work the holes with a tap and apply plenty of grease on fitting, to ensure easy removal, the studs into both the side of the runner rail and the larger ones into the underbelly all have a propensity to rust and seize and snap on removal attempts .
Post #488842 13th Sep 2018 6:50pm
gj88
United Kingdom 2004 Range Rover Vogue Td6 Zambezi Silver
Depending on the steps you're looking at, it may be cheaper to buy the IIDTool and lower the access height settings by 15mm or so, makes a massive difference. You've then got the tool for all the other stuff you'll definitely need it for in the long run!
Post #488858 13th Sep 2018 9:26pm
Bought a set of these recently
https://www.ebay.co.uk/itm/Land-Rover-Rang...Swc-tY3dEP
and having just removed old OEM and replaced with 2nd hand OEM, then fitted the above, can say no real difference other than the front mudflap and connection to it being a bit different, however fitting and alignment perfect, no complaints, and from casual observation look the same as OEM. .
Post #488859 13th Sep 2018 10:38pm
TedwoodLawler
There are some really good deals on fleabay for new genuine deployables occasionally from JLR dealerships. Today there is one fewer. Spanners will be out soon. Very Happy
Post #488868 14th Sep 2018 7:57am
Not sure how different your fitting will be, but NMJ wrote up his installation here Thumbs Up
Post #488869 14th Sep 2018 8:32am
TedwoodLawler
Post #488870 14th Sep 2018 8:45am
Weegie
And the deployables are about half the price of the fixed LR ones which are about £800 Shocked Fitting is obviously more complicated on the deployables where the ECU and wiring have to be installed.
I had these fitted to replace aftermarket which were in a poor state:
https://www.sidesteps.co.uk/shop/side-step...ide-steps/
Dearer than the ones Joe90 has linked but I am very pleased with them. John
GAP iiD BT
Post #488872 14th Sep 2018 9:24am
