![]() | Home > Maintenance & Mods (L322) > Silly question from a newbie.... |
Rosco Member Since: 20 Jan 2012 Location: Beyond the wall. Posts: 2587 ![]() ![]() ![]() |
There are holes pre drilled on the chassis to take side steps, the plastic covering is irrelevant and stays put. |
It is a sensible thing to do, saves trouble with the seat bolster and seat plastic surround which get worn and damaged with the "sliding off"
gj88 Member Since: 10 Sep 2018 Location: West Midlands Posts: 213 ![]() ![]() ![]() |
Depending on the steps you're looking at, it may be cheaper to buy the IIDTool and lower the access height settings by 15mm or so, makes a massive difference. You've then got the tool for all the other stuff you'll definitely need it for in the long run! |
Bought a set of these recently
TedwoodLawler Member Since: 16 Jul 2018 Location: Tunbridge Wells Posts: 6 ![]() ![]() ![]() |
There are some really good deals on fleabay for new genuine deployables occasionally from JLR dealerships. Today there is one fewer. Spanners will be out soon. |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7971 ![]() ![]() ![]() |
Not sure how different your fitting will be, but NMJ wrote up his installation here |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3246 ![]() ![]() ![]() |
And the deployables are about half the price of the fixed LR ones which are about £800 ![]() I had these fitted to replace aftermarket which were in a poor state: https://www.sidesteps.co.uk/shop/side-step...ide-steps/ Dearer than the ones Joe90 has linked but I am very pleased with them. John 2008 Stornoway Grey 3.6 Tdv8 Vogue 2005 TD6 Java Black Vogue - Written off!! GAP iiD BT 2003 Discovery TD5 Auto, Nanocom Evolution - gone to a new home! MasseyFerguson 152 - No electronics!! - Sold |
