Home > Technical (L322) > 6hp26 shift issues 3.6TDV8 |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1747 |
I started panicking once my oil temp got upto 105 degrees, after a long slog up the Shap summit with an RRS in tow...
17th May 2018 7:45pm |
elandri Member Since: 28 Apr 2015 Location: Norwich Posts: 43 |
Yes, Range Rovers seem to generate a healthy dose of paranoia in their owners!
25th May 2018 7:51am |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 962 |
It’s a shortened version of ‘Magnetventil’ – the German word for an ‘on-off’ electromagnetic solenoid. The nearest English equivalents are Magnetic Valve, Solenoid Valve, Shift Solenoid, etc.
25th May 2018 9:53am |
Phil,
29th May 2018 2:02pm |
Hmmm, well none of the clutches/brakes appear to be slipping:
29th May 2018 11:51pm |
Well, if the brakes and clutches aren't slipping I guess we have to think that's a good thing! Nice graph by the way.
30th May 2018 10:33pm |
The hydrodynamic function of the TC won't, but its lock-up clutch actuation might
Engine, turbine and output speed plus EDS6 solenoid current would be minimum. If there's an engine torque or throttle position measurement available too, that would be ideal. Just need a light-throttle acceleration through all the gears from stationary to (say) 60-65mph, holding the throttle as constant as possible, and then a further run at a wider (half?) throttle opening. I recognise that it's a pain finding somewhere you can (legally) accelerate 'gently' up to 65mph from rest, but unfortunately the LUC won't fully engage until you're up at the higher speed. Phil |
31st May 2018 10:04am |
Unfortunately, I’m a bit snowed under with work at the minute, so I haven’t had the opportunity yet to look at all the IIDTool data that elandri has kindly sent through. I have, however, just had a quick glance at the first light-throttle acceleration run and it’s interesting to see that the torque converter lock-up clutch is completely off in 1st & 2nd gears and is activated while the transmission is accelerating in 3rd gear. You can see on the graph that, from when the LUC is switched on, the engine speed just ‘hangs’ for almost 3 seconds, until 4th gear is engaged. Once in 4th gear the LUC slip is accurately controlled at 4%. In 5th and 6th gears the LUC is fully locked (i.e. turbine speed = engine speed).
2nd Jun 2018 12:28am |
I’ve finally got around to checking through all of the acceleration runs that elandri measured with the IIDTool; two at light throttle, two at medium and three at heavy throttle.
13th Jun 2018 11:25am |
cheezels Member Since: 23 Apr 2016 Location: Sunshine Coast Posts: 279 |
I’d be more than happy to help. I’ve found this thread very interesting.
13th Jun 2018 11:43am |
Thank you, cheezels. The four parameters that need recording are:
13th Jun 2018 2:21pm |
cheezels has very kindly provided a set of acceleration-from-rest results from his 2007 3.6 TDV8, measured using the IIDTool.
4th Jul 2018 10:26pm |
Aarrgghh!
4th Sep 2018 5:15pm |
unsolicited Member Since: 30 May 2016 Location: London Posts: 124 |
You have tried resetting engine adaptations? It made a huge difference to my S/C when the box was doing strange things. |
5th Sep 2018 5:00pm |
