![]() | Home > Technical (L322) > 6hp26 shift issues 3.6TDV8 |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1814 ![]() ![]() |
I started panicking once my oil temp got upto 105 degrees, after a long slog up the Shap summit with an RRS in tow...
elandri Member Since: 28 Apr 2015 Location: Norwich Posts: 43 ![]() ![]() ![]() |
Yes, Range Rovers seem to generate a healthy dose of paranoia in their owners!
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 1000 ![]() ![]() |
It’s a shortened version of ‘Magnetventil’ – the German word for an ‘on-off’ electromagnetic solenoid. The nearest English equivalents are Magnetic Valve, Solenoid Valve, Shift Solenoid, etc.
Phil,
Hmmm, well none of the clutches/brakes appear to be slipping:
and, if any of them were, the controller would detect it and immediately throw a failsafe error. Edit : Might it be possible to post up the list of the “101 (ish) parameters” that the IIDTool can record for the transmission? I’d be interested to have a read through the list to see if anything stands out as being of potential use. Edit : Also, might it be possible to capture some data which includes the current for the EDS6 solenoid, so we can check what the torque converter is up to? (i.e. engine, turbine & output speeds plus EDS6 current). Phil |
Well, if the brakes and clutches aren't slipping I guess we have to think that's a good thing! Nice graph by the way.
The hydrodynamic function of the TC won't, but its lock-up clutch actuation might
Engine, turbine and output speed plus EDS6 solenoid current would be minimum. If there's an engine torque or throttle position measurement available too, that would be ideal. Just need a light-throttle acceleration through all the gears from stationary to (say) 60-65mph, holding the throttle as constant as possible, and then a further run at a wider (half?) throttle opening. I recognise that it's a pain finding somewhere you can (legally) accelerate 'gently' up to 65mph from rest, but unfortunately the LUC won't fully engage until you're up at the higher speed. Phil |
Unfortunately, I’m a bit snowed under with work at the minute, so I haven’t had the opportunity yet to look at all the IIDTool data that elandri has kindly sent through. I have, however, just had a quick glance at the first light-throttle acceleration run and it’s interesting to see that the torque converter lock-up clutch is completely off in 1st & 2nd gears and is activated while the transmission is accelerating in 3rd gear. You can see on the graph that, from when the LUC is switched on, the engine speed just ‘hangs’ for almost 3 seconds, until 4th gear is engaged. Once in 4th gear the LUC slip is accurately controlled at 4%. In 5th and 6th gears the LUC is fully locked (i.e. turbine speed = engine speed).
As with the previous data, when comparing the output speed and turbine speed data it is clear that none of the clutch packs inside the transmission are slipping. I’ll look at the remaining measurements as soon as I get a minute. Phil |
I’ve finally got around to checking through all of the acceleration runs that elandri measured with the IIDTool; two at light throttle, two at medium and three at heavy throttle.
What’s clear from all of the traces is that, during acceleration, the torque converter lock-up clutch is always activated in 3rd gear, irrespective of the performance level demanded by the driver. The LUC takes around 2 seconds (again, independent of throttle opening) to bring the speed ratio up towards unity in 3rd gear. For 4th gear the LUC appears to operate in a controlled continuous-slip mode (at around 4% slip speed) and then the LUC is fully locked in 5th and 6th gears, for economy. I can’t see anything in the traces that might indicate this is anything other than Land Rover/ZF’s intended control philosophy, as it is so repeatable, but clearly this is based on a sample of one. Ideally, results from other vehicles would be required to provide a comparison, to confirm this (any volunteers?). In summary, in the absence of comparative data, I would say what’s being perceived as a fault here is simply the torque converter and control system correctly doing their jobs. Phil |
cheezels Member Since: 23 Apr 2016 Location: Sunshine Coast Posts: 279 ![]() ![]() ![]() |
I’d be more than happy to help. I’ve found this thread very interesting.
Thank you, cheezels. The four parameters that need recording are:
cheezels has very kindly provided a set of acceleration-from-rest results from his 2007 3.6 TDV8, measured using the IIDTool.
Interestingly, though, the medium and hard throttle runs look a bit different.
This time, the lock-up clutch is triggered immediately following the 1-2 shift, pulling the engine speed down in 2nd gear. The lock-up clutch is then locked solid in 3rd & higher gears. I think some of the difference relates to the inevitable variance in the calibration of the two drivers’ right feet. From the engine speeds, it can be seen that cheezels’ ‘medium’ throttle is equivalent to elandri’s ‘hard’ throttle, and elandri’s results for hard throttle do show the LUC being activated momentarily immediately following the 1-2 upshift but the signal is then cancelled, only to return again once the 2-3 upshift has taken place. Phil |
Aarrgghh!
unsolicited Member Since: 30 May 2016 Location: Bucks Posts: 130 ![]() ![]() ![]() |
You have tried resetting engine adaptations? It made a huge difference to my S/C when the box was doing strange things. |
