![]() | Home > Technical (L322) > IIDTool from gap diagnostics ***Q & A *** |
Bluegreygreen Rangie Member Since: 10 Aug 2012 Location: Australia Posts: 53 ![]() ![]() |
That's very interesting.. Thank you
Zim Member Since: 04 Mar 2018 Location: Market Harborough Posts: 27 ![]() ![]() ![]() |
I received my BT IID Tool yesterday. The service from Pat and team is exceptional, thanks for the help getting it up and running very quickly.
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 ![]() ![]() ![]() |
pull the fuse out, weight for the right time and plug fuse beck in. |
Clabs Member Since: 08 Mar 2017 Location: Watford, Herts Posts: 125 ![]() ![]() |
Rob
carpcat Member Since: 13 Oct 2017 Location: Surrey Posts: 58 ![]() ![]() ![]() |
Mark, I have the same sensor issue and the memory does not work, although the manual movement works fine. Sounds like a sensor replacement of some sort required? Chris |
Hey Mark,
Chris and Rob - thanks for the feedback.
Andyyav Member Since: 13 Mar 2017 Location: Norfolk Posts: 139 ![]() ![]() ![]() |
Morning All
Andy Member Since: 23 Feb 2009 Location: Shropshire Posts: 2942 ![]() ![]() ![]() |
Can the IID tool show live values for the suspension height sensors and whether they are working correctly? |
Simes Member Since: 30 Aug 2011 Location: Hinckley Posts: 964 ![]() ![]() ![]() |
Quick question - where do I look in the live values to see the quantity of soot lurking in the DPF? I've seen a pic on the DPF thread showing it in grams - but I can't find that anywhere! |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3788 ![]() ![]() ![]() |
If you scroll down live values then select engine.
Thanks BB.
Bottom right in picture.
Cheers...
