Home > Technical (L322) > IIDTool from gap diagnostics ***Q & A *** |
Bluegreygreen Rangie Member Since: 10 Aug 2012 Location: Australia Posts: 53 |
That's very interesting.. Thank you
28th Feb 2018 11:44am |
Zim Member Since: 04 Mar 2018 Location: Market Harborough Posts: 27 |
I received my BT IID Tool yesterday. The service from Pat and team is exceptional, thanks for the help getting it up and running very quickly.
9th Mar 2018 9:56am |
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 |
pull the fuse out, weight for the right time and plug fuse beck in.
9th Mar 2018 1:00pm |
Clabs Member Since: 08 Mar 2017 Location: Watford, Herts Posts: 125 |
Rob
9th Mar 2018 9:03pm |
carpcat Member Since: 13 Oct 2017 Location: Surrey Posts: 58 |
Mark, I have the same sensor issue and the memory does not work, although the manual movement works fine. Sounds like a sensor replacement of some sort required? Chris |
9th Mar 2018 10:49pm |
Hey Mark,
10th Mar 2018 11:40am |
Chris and Rob - thanks for the feedback.
10th Mar 2018 8:41pm |
Andyyav Member Since: 13 Mar 2017 Location: Norfolk Posts: 137 |
Morning All
14th Apr 2018 8:25am |
Andy Member Since: 23 Feb 2009 Location: Shropshire Posts: 2938 |
Can the IID tool show live values for the suspension height sensors and whether they are working correctly? |
25th Aug 2018 12:57pm |
Simes Member Since: 30 Aug 2011 Location: Hinckley Posts: 964 |
Quick question - where do I look in the live values to see the quantity of soot lurking in the DPF? I've seen a pic on the DPF thread showing it in grams - but I can't find that anywhere! |
3rd Sep 2018 10:20am |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3766 |
If you scroll down live values then select engine.
3rd Sep 2018 10:37am |
Thanks BB.
3rd Sep 2018 10:39am |
Bottom right in picture.
3rd Sep 2018 10:51am |
Cheers...
3rd Sep 2018 10:57am |
