Home > Technical (L322) > L322 Range Rover "FUEL INJECTOR SYTEM" ERROR MESSA |
AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1464 |
"intank diesel pump was siezed due to cheap petrols from well known supermarkets"
2nd Sep 2018 11:47am |
David59 Member Since: 02 Sep 2018 Location: London Posts: 3 |
Hi, thanks but do you have any idea about the message "Fuel injector system" on the dash? or just angry about the cheap diesel issue.?
2nd Sep 2018 11:58am |
Apologies for commenting, i have no idea about the message only experience of supermarket fuels which come from the exact same tanks as premium fuels. For more information on the urban myths that you spread https://www.allstarcard.co.uk/this-matters...rket-fuel/
2nd Sep 2018 12:18pm |
wayneg Member Since: 05 Jun 2013 Location: South Fremantle, Australia ( ex London ) Posts: 791 |
There is a pressure sensor on top of the fuel filter, if the pressure is to low you get the " Fuel injector system error" message. As the pumps have been replaced I would put a new fuel filter in and check the plug for a good connection. My understanding is that algae in the fuel is a bigger problem if moisture is also in the tank. Moisture should separate in the filter and settle in the bottom, maybe that could trigger the warning too? 2007 TDV8 VSE
3rd Sep 2018 1:06pm |
Hi wayneg, Thank you for your sensible explanations. It very much makes sence what you have said here about the "fuel injector sensor error"issue.
3rd Sep 2018 7:45pm |
