![]() | Home > Maintenance & Mods (L322) > Rear seat heater switches |
bruno22rf Member Since: 08 Mar 2018 Location: milton keynes Posts: 69 ![]() ![]() ![]() |
04 L322 - The rear switch for the seat heater is not working - when I push it in the light comes on but then goes out as soon as you remove your finger - closer inspection has revealed that the switch is actually broken around the tiny light sections - I want to try swapping the switches over to make sure that the switch is why the seat is not working but I cannot find any information about removing said switch. The panel has 2 seat switches and an Aux power outlet. |
M17tph - you Sir, are a genius - sincerest thanks |
