Home > Maintenance & Mods (L322) > Rear seat heater switches
bruno22rf
England 2004 Range Rover Vogue 4.4 V8 Java Black
04 L322 - The rear switch for the seat heater is not working - when I push it in the light comes on but then goes out as soon as you remove your finger - closer inspection has revealed that the switch is actually broken around the tiny light sections - I want to try swapping the switches over to make sure that the switch is why the seat is not working but I cannot find any information about removing said switch. The panel has 2 seat switches and an Aux power outlet.
Post #487272 27th Aug 2018 1:37pm
M17tph
England 2006 Range Rover Vogue SE Td6 Buckingham Blue
Go on to the powerfuluk website look in interior trim you will find the rear switch panel then scroll down there is a video of how to remove it
Post #487291 27th Aug 2018 3:57pm
bruno22rf
M17tph - you Sir, are a genius - sincerest thanks Thumbs Up .
Post #487337 28th Aug 2018 7:00am
