Home > Maintenance & Mods (L322) > front suspension air bag
dpm
United Kingdom 2012 Range Rover Westminster 4.4 V8 Stornoway Grey
I'm trying to fit a new airbag to the old strut, managed to get the big nut from the top undone by cutting old bag and putting damper shaft in vice, with protection,. any idea how i can tighten the nut up when the new airbag is in place.
Post #487001 24th Aug 2018 11:14am
Does this help ?
Post #487024 24th Aug 2018 4:08pm
dpm
the problem is the whole shaft spins as you tighten the nut.
Post #487033 24th Aug 2018 5:59pm
mm289
United Kingdom 2011 Range Rover Autobiography 4.4 V8 Ipanema Sand
Is there not an allen key hole in the top of the shaft?
MM 2011 TDV8 AB
2006 TD6 AB (Gone to Wales)
Post #487050 24th Aug 2018 7:24pm
Baltic Blue
I can’t find the answer in the WM, but 90Nm is pretty tight, so it surely locks with a peg or similar?
Post #487061 24th Aug 2018 8:31pm
dpm
There is an allen key hole on top of the shaft but the problem is then getting a socket on.
Post #487091 25th Aug 2018 9:56am
GraemeS
Use a ring spanner to hold the nut and a torque wrench on a hex socket.
Post #487092 25th Aug 2018 10:02am
dpm
Don't think the hex would be able to take 90Nm of force it would strip the corners off.
Post #487093 25th Aug 2018 10:10am
GraemeS
I've loosened then re-tightened mine with a ring spanner and an Allen key, checking that the nuts were tight.
Post #487100 25th Aug 2018 11:00am
dpm
All done, put the allen key socket in a vice then tightend nut with ring spanner. thanks for all the help.
Post #487167 26th Aug 2018 7:20am
