![]() | Home > Maintenance & Mods (L322) > Letter template |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6409 ![]() ![]() |
See here from wiki (might help):
Full Fattie Member Since: 10 Aug 2018 Location: Sunderland Posts: 245 ![]() ![]() ![]() |
I think I should have masked it up, looks like a good job doing it that way. I’ll hope that if I can get the template in the right place then I should be good. |
It should be in the centre, so just get your measurements right for bonnet and boot edge to edge to find the centre mark. If you need a measure from the bottom edge of bonnet or boot, we will all get out there with tape measures to give a range of values you can average |
I wish it was that simple but the template comes in 2 parts, one for each word, not exactly ideal.
Gap between words, Bonnet and Boot @ 9.5 cm
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16288 ![]() ![]() ![]() |
Why not find another RR and using masking tape, make yourself a template that you can simply pull off and stick on your bonnet & boot |
I was thinking of doing just that but the 2 people I know with a Range Rover have a P38, the other has a new sport so either are exactly the same shape. |
Remember: measure twice, thrice and stick once |
Is there a LR dealership nearby your location? Im sure they would be happy for you to attend their premises and take some measurements/masking measurements |
