Home > Maintenance & Mods (L322) > Letter template
Full Fattie
United Kingdom 2007 Range Rover Vogue SE 4.2 SC V8 Zambezi Silver
Letter template
I’ve recently removed my bonnet and boot letters to give the bodywork a full polish. I’m replacing the badges now but when they’ve arrived they only come with a template to show the spacing between each letter. What I ideally need, and wrongly expected, is a full template that goes to the edge of the bonnet and boot to show where the letters should start. Are these available anywhere?
Post #486531 19th Aug 2018 8:48am
See here from wiki (might help):
http://www.fullfatrr.com/forum/topic31624.html
I have a VOGUE SE template if that would help? .
Post #486546 19th Aug 2018 10:56am
Full Fattie
I think I should have masked it up, looks like a good job doing it that way. I’ll hope that if I can get the template in the right place then I should be good.
Post #486581 19th Aug 2018 5:03pm
It should be in the centre, so just get your measurements right for bonnet and boot edge to edge to find the centre mark. If you need a measure from the bottom edge of bonnet or boot, we will all get out there with tape measures to give a range of values you can average Smile
FWIW
Bonnet, from edge of headlight (wing edge) to edge :196 cm
Bonnet, inner groove to inner groove: 107 cm
Bonnet letters from bottom edge: 24 mm
Boot, edge to edge: 137.5 cm
Boot, letters from bottom edge: 41 mm .
Post #486594 19th Aug 2018 6:09pm
Full Fattie
I wish it was that simple but the template comes in 2 parts, one for each word, not exactly ideal.
Thanks for offering to measure the bottom to top, I might need to take you up on that offer. Also if you could measure the gap between the 2 words would be even better.
Post #486617 19th Aug 2018 9:51pm
Gap between words, Bonnet and Boot @ 9.5 cm
Attached VOGUE SE template (A4)
http://www.fullfatrr.com/gallery/albums/us...oguese.pdf .
Post #486619 19th Aug 2018 10:42pm
Why not find another RR and using masking tape, make yourself a template that you can simply pull off and stick on your bonnet & boot Thumbs Up
Post #486623 19th Aug 2018 11:39pm
Full Fattie
I was thinking of doing just that but the 2 people I know with a Range Rover have a P38, the other has a new sport so either are exactly the same shape.
Post #486643 20th Aug 2018 9:39am
Remember: measure twice, thrice and stick once Wink (from a carpenter's meme I always forget to use when i have a saw in my hand Embarassed ) .
Post #486648 20th Aug 2018 11:27am
Is there a LR dealership nearby your location? Im sure they would be happy for you to attend their premises and take some measurements/masking measurements Thumbs Up
Post #486692 20th Aug 2018 9:55pm
