Home > Technical (L322) > Dash lights dimmer
Balloonengineer
Dash lights dimmer
I would like to dim my 55 plate Denso touch screen, I find it very distractingly bright at night. So much I often turn it off.
Of course I have turned down the brightness on the screen control, and it is also connected to the dash dim knob.
Its about the right brightness when the dash is turned to its lowest, however that then dims all the other lights, speedo etc.
It is obviously a variable resistor, but can't find the circuit on the L322 wiring diagram.
I was hoping that I could either fit another (or a resistor) in line just before the Denso screen.
Can anybody cast their eye over the wiring diagram and spot it, or any ideas of which pin-out the dimmer circuit is,
Or other ideas gratefully received.
Many thanks
Glen Previously......
Series 1 80, Series 3 88, Turbo 90, 300tdi 90, 110's with 200, 300, TD5
TD5 Disco, Disco 3, 200Tdi Disco - probably the best vehicle Landrover ever made,
Now 3x FFRR, some would say I should have learned by now......
Post #485660 10th Aug 2018 7:50pm
GraemeS
I expect the dimmer to be generating a PWM signal varying the ON time rather than being a variable resistor.
My MY12's dimmer is part of the lighting switch and shows there in the wiring schematic.
Post #485665 10th Aug 2018 8:59pm
Balloonengineer
Thanks, but I suspect a 2012 is probably significantly different to a 2005 year.
Can anybody find the dimmer circuit diagram for a 2005/6? or any other dimmer ideas?
Best wishes
Post #485893 13th Aug 2018 8:00am
i turn mine off at night if on a long journey...
there isnt a way of dimming the screen unfortunately but if you do need it on then what about a piece of coloured perspex/plastic or any other 'diffused' see through material that you can place over the screen... ... - .- -.
Post #485896 13th Aug 2018 8:23am
rjff
Glen
Stan has a very good idea. If you're stuck for a form of cover, search "theatre lighting gels".
Lots about and many different shades and don't appear to expensive.
Cheers
Richard
Post #485910 13th Aug 2018 10:17am
GraemeS
If your dimmer control is in the light switch then my guess is that it will not have changed. The dimmer fitted to 1999 D2s were pwm controlled and IIRC D1's were too.
Post #485916 13th Aug 2018 10:28am
Balloonengineer
A tinted ipad screen protector would probably be an answer if such a thing existed??
I wonder if window tint film would work. Has anybody got any they could try to see if you can 'finger' through it Laughing
Best wishes
Post #486190 15th Aug 2018 4:35pm
Highroller
United Kingdom 2005 Range Rover Vogue SE 4.4 V8 Java Black
Just a point, would the touch screen still operate ok with the additional cover?.
I agree with the brightness & tend to use the voice control to turn it off. Thumbs Up
Post #486191 15th Aug 2018 4:38pm
