![]() | Home > Wheels & Tyres > General Grabber AT3 255 55 R20 |
verydisco Member Since: 10 Dec 2009 Location: UK/US Posts: 2952 ![]() ![]() ![]() |
Interested in the same matter, same tyres but for an L405. |
RiDDO Member Since: 13 Nov 2015 Location: Lincolnshire Posts: 33 ![]() ![]() ![]() |
Have covered about 400 miles or so since the tyres were fitted. My speedo is more accurate than it was before! With 255 50's its was always 2mph faster then my GPS indicated (30=32mph), I trust my GPS more! The ride is definitely better. I have not adjusted the pressures yet 33psi front & 36psi rear. Will update again in a week or two.
Thank you for the update Ian |
Andyyav Member Since: 13 Mar 2017 Location: Norfolk Posts: 164 ![]() ![]() ![]() |
I run these on 36 front and 38 rear, no issues so far, not sure how much difference a few PSI makes! |
Thanks for the pressure advice Andyyav, I will try mine on the same and post. --RiDDO |
FlyingTrotter Member Since: 10 Nov 2013 Location: London Posts: 79 ![]() ![]() ![]() |
Just put a new set of wheels with some Grabbers on - love the look and the feel inc the not appreciably greater noise on first drive
TJH1985 Member Since: 11 Feb 2015 Location: Nottingham Posts: 664 ![]() ![]() ![]() |
Got them here as well - Love them |
19sjw Member Since: 18 Oct 2014 Location: East Anglia Posts: 25 ![]() ![]() ![]() |
Me too,36 front,42 rear. |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4332 ![]() ![]() ![]() |
Post some pics please |
Harlequin Member Since: 26 Sep 2018 Location: Crowborough Posts: 57 ![]() ![]() ![]() |
Hi guys
nearlee Member Since: 28 Feb 2018 Location: Where the sheep are scared Posts: 250 ![]() ![]() |
Same tyres, 42psi all round.
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3782 ![]() ![]() |
@42 psi there is no wonder - you are over inflating unless you are running at max gvw, I did around 80k on generals in an L322 and light load pressures are more than ample - they have very stiff sidewalls 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17 |
Grofus Member Since: 24 Mar 2017 Location: Co Clare Posts: 577 ![]() ![]() ![]() |
As above chap. I run mine 34 psi all round and are great on wet, dry roads , mud. On snow they are way better than a road tyre but not as good as dedicated winter tyres.
martinf Member Since: 26 Dec 2014 Location: sussex Posts: 256 ![]() ![]() ![]() |
Totally agree. I use 34 and 37 which is fine. |
