Home > Wheels & Tyres > General Grabber AT3 255 55 R20
Page 4 of 8 <12345678>
AndrewM
No problem Mike
You may have to inflate to only about 25 or so (Not the full 33/36) & it just takes a bit of a "wiggle" to fit in the well - But DOES fit. I've had them on the car for 3 weeks now & I must say the drive and smoothness has improved dramatically. I've also used on the motorway a few times & no more noise than Scorions fitted,before.
Definately recommend them! (& they're cheaper!)
Post #509641 23rd Mar 2019 4:55pm
DrRob
Andrew - any fouling issues with the 55 profile AT3? Does the plastic wheel arch liner nr fuel filler pipe need heating and pushing in a bit as some folks have had to do?
Thanks, Rob Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #525449 19th Aug 2019 7:57pm
AndrewM
Hi Rob;
No fouling issues with the 55 profile, that i know of?
Done a few '000 miles now & no problems whatsoever...apart from sitting marginally taller in vehicle (55 as opposed to 50 on Scorpions)
I take it to a specialist LR workshop for all its servicing/MOT's etc. + never commented on it & just passed its MOT , too.
I think you may be confusing it with the GG AT3 45/75 (which is a lower, wider profile) and i have seen on this blog that you will have to do some adjustments for those.
I must say; These tyres are brilliant & so much smoother (Again; A higher profile than Scorpions) + not any noisier than the previous Pirelli Scorpions.
Havent had a chance to use in the mud & snow, yet...But winter isnt far off!
But I would definately fit them again & recommend them.
Post #525534 20th Aug 2019 2:25pm
chicrange
United Kingdom 2006 Range Rover SE Td6 Adriatic Blue
Tugger wrote:
If anyone has a pic or two of the 55 profile Grabbers on an L322, would you mind sharing? I'm approaching the point when I need new tyres but I'd like to see how they look in real life on a car, rather than just a pic of the bare tyre on a website.
I know it is few years old but here is my Fatty L322 with Grabbers AT3 pressure @ 36psi all round.
[/img]
Post #592798 30th Apr 2021 4:21pm
Doug86
I got a set of these fitted last week, they're incredible.
Now, reading this thread, it seems that the spare really needs to be changed out as well. Is that the case for certain? Seems like such a waste chucking a brand new spare (255/50/20).
Post #616108 13th Dec 2021 1:00pm
i have throughout the years bought many sets of [4] wheels and have ended up with an odd spare..
my thoughts are that if you did have a puncture on the road wheel ,you treat the 'odd' spare as a space saver to get you to a tyre shop or home...
you obviously take care in driving/speed.. ... - .- -.
Post #616120 13th Dec 2021 1:32pm
grey17
United Kingdom 2010 Range Rover Vogue SE TDV8 Alaska White
Hi Stan.
It can't be a "space saver" style wheel as it is smaller in diameter and circumference, I wouldn't give the diff a healthy prognosis in this case.
G
Post #616130 13th Dec 2021 1:46pm
understood..
you could take off the new tyre sell it and stick an appropriate sized worn tyre on .. ... - .- -.
Post #616134 13th Dec 2021 2:03pm
grey17
That would work, yes.
G
Post #616138 13th Dec 2021 2:21pm
LT
This is the right size, albeit not the same tyre:
https://www.disco3.co.uk/forum/sale-new-25...97228.html
Post #616159 13th Dec 2021 5:19pm
set of 4 nearly new 255/55/20 at3's on wheels including tpms valves here for £700,
https://www.disco4.com/forum/sale-gg-at3-s...98434.html ... - .- -.
Post #616161 13th Dec 2021 5:29pm
Chieflongshin
United Kingdom 2011 Range Rover Vogue 4.4 V8 Barolo Black
Morning all
For those that have had these on their car a year or so. How have they lasted. I’m close to pulling the trigger on a set and just wanted to check they don’t rub or anything etc
Thank you
Post #616690 17th Dec 2021 6:51am
JayGee
Worth checking this out before you 'pull the trigger'
https://www.tyrereviews.com/Article/2018-A...e-Test.htm 2012 TDV8 Vogue (L322)
Post #616691 17th Dec 2021 7:26am
Chieflongshin
Thank you for sharing that. That's bit of a "how do I drive " consideration to add into the equation now. I wonder if they'd have changed much in three years
Post #616693 17th Dec 2021 8:05am
JayGee
I doubt it otherwise they would be called AT4.....
IME wet braking is the No1 quality I look for in a tyre. All tyres grip well enough in the dry and if you are loosing traction on the road in the dry you are simply driving way too fast. I'd consider Grabbers if I was regularly needing to do a lot of off road but they are too compromised in wet conditions for mainly road use IMO. 2012 TDV8 Vogue (L322)
Post #616695 17th Dec 2021 8:31am
