![]() | Home > Maintenance & Mods (L405) > Do I need an AirCon refrigerant change? |
Andy B Member Since: 03 Apr 2012 Location: West Malling Posts: 1223 ![]() ![]() |
http://www.fullfatrr.com/forum/topic48142.html
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16311 ![]() ![]() ![]() |
Tis a very expensive Gas in the L405's I'm afraid...
Bill Member Since: 18 Nov 2017 Location: Essex / Normandy Posts: 1245 ![]() ![]() |
Cam tech-C said
Why change the refrigerant if the ac is working correctly? |
Dixy Member Since: 09 Apr 2009 Location: Somerset Posts: 1101 ![]() ![]() |
From where does it gain moisture, the refrigerant must be in a sealed system.
cheezels Member Since: 23 Apr 2016 Location: Sunshine Coast Posts: 279 ![]() ![]() ![]() |
No need to change refrigerant.
Why would an AC system have a "drier" if there were no moisture to dry??? ![]() |
Unfortunately, it is nigh on impossible to achieve a perfect vacuum and remove all traces of air (which carries the moisture) from the system, during the time allocated for initial “commissioning”.
I thought the drier dehumidified the air being blown in to the car not the refrigerant. letters not necessarily in the right order |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3550 ![]() ![]() ![]() |
My air con home unit gained moisture from the copper pipes being a little gas permeable. The proliferation of cheaper copper pipework allows moisture in according to my service engineer.
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1351 ![]() ![]() |
he's blowing smoke up yer arse though |
another way of saying it: Chinese copper
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3756 ![]() ![]() |
Personally I would wait until you notice a difference with the a/c temp and do it when needed 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17 |
Given the pressures inside the refrigerant pipework relative to outside air I would have thought any gas migration including moisture would be from the pipework outwards not inwards. Could be wrong though. ![]() |
