![]() | Home > Maintenance & Mods (L405) > Do I need an AirCon refrigerant change? |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1365 ![]() ![]() |
Or other miniscule leak paths |
appj62 Member Since: 07 Aug 2013 Location: Cheshire Posts: 424 ![]() ![]() ![]() |
Mine is over 15 years old now (I've had it for over 8 ). No change or top up of refrigerant has been required. Don't always run with the A/C on but occasionally switch on, just to ensure compressor seal doesn't "dry" out. 'If it ain't broke, don't fix it'! Previous cars:
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2681 ![]() ![]() ![]() |
Mine smells on start up , think it needs a service . |
AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1464 ![]() ![]() ![]() |
Just get yourself an aircon bomb from a motor accessory shop. You close the windows, put the aircon on full cold and recirculating air, set the thing off and close the doors. It kills the bacteria in the evaporator that makes the smell. Should be less than £10.
Aye , did that last week with a new filter, still doesn’t smell 100% |
