Home > Maintenance & Mods (L405) > Do I need an AirCon refrigerant change?
Page 1 of 3 123>
martinf
United Kingdom 2016 Range Rover Vogue TDV6 Santorini Black
I just arranged a service for my L405 as it will be 3 years old shortly.
The dealer suggested that I have the AirCon serviced which involves replacing all the refrigerant at a cost of £250! Apparently the refrigerant in the L405 is much more expensive than in older vehicles.
This is not something that Porsche have suggested on my Boxster or BMW on my Cooper S so my question is whether it has any advantages and, also, do JLR include it in their service schedule?
Post #484916 1st Aug 2018 4:18pm
Andy B
http://www.fullfatrr.com/forum/topic48142.html
Certain Halfrauds will do it with the new type gas for £120 including a clean. SDV8 AB MY 2019
SDV8 VSE MY 2015 - Gone
5.0 S/C AB MY 2010 - Gone
4.2 S/C VSE MY 2006 - Gone
Post #484922 1st Aug 2018 4:39pm
Tis a very expensive Gas in the L405's I'm afraid...
Ive just spoken to my AC "Man" and the industry standard is now every two years!!! Due to refrigerant loss & moisture gain! "from an environmental stand point, it takes more of your engines power to refrigerate the air after 24 months" therefore harms the environment... Confused
Post #484928 1st Aug 2018 5:30pm
Bill
Unquote
Censored & every two years , double Censored
I hope/suspect prices will in future come down as more widely used . Filters are in fact so good that in certain circumstances, when the ambient air is already polluted, a diesel car will tend to extract more particles from the air than it emits. Emissions Analytics worked with........etc etc
He who dies with the most toys wins...
Post #484992 2nd Aug 2018 10:35am
Why change the refrigerant if the ac is working correctly?
Post #484997 2nd Aug 2018 10:52am
Dixy
2016 Range Rover Vogue SDV8 Loire Blue
From where does it gain moisture, the refrigerant must be in a sealed system.
Perhaps it has to be changed to cover up the smell of bullshit. letters not necessarily in the right order
Post #485000 2nd Aug 2018 11:18am
cheezels
Australia 2007 Range Rover Vogue TDV8 Java Black
No need to change refrigerant.
One replaces refrigerant after securing a leak.
The dryer will remove any moisture, of which there shouldn’t be any, if the system was commissioned correctly.
Out of interest, the system is vacuumed (during commissioning or after fault rectification) not only to check for leaks but to also “boil” any moisture to allow for easier evacuation. Sometimes the moisture can be seen to freeze, if there is a lot of it (say in a very humid environment). Pressure is raised (or heat applied) to allow this to melt.
Hmmm, I digressed a bit.
If it works. Leave it alone.
If you were that way inclined, you could record the HP pressure with an IIDtool every once in a while to monitor for pressure loss and hence a leak.
I’ve worked on AC systems for 25 years on ships and I’ve never heard of changing refrigerant as a maintenance measure. 2007 3.6 TDV8
Post #485002 2nd Aug 2018 11:30am
Why would an AC system have a "drier" if there were no moisture to dry??? Whistle
Post #485031 2nd Aug 2018 10:09pm
cheezels
Unfortunately, it is nigh on impossible to achieve a perfect vacuum and remove all traces of air (which carries the moisture) from the system, during the time allocated for initial “commissioning”.
Any debri, say welding slag or just dirt, will eventually be caught in the drier, which has the dual role of “filter/drier”, during system operation.
Moisture can get into the system when a technician connects his gauges and doesn’t purge enough, though 2007 3.6 TDV8
Post #485038 3rd Aug 2018 1:39am
Dixy
I thought the drier dehumidified the air being blown in to the car not the refrigerant. letters not necessarily in the right order
Post #485058 3rd Aug 2018 11:45am
GGDR
My air con home unit gained moisture from the copper pipes being a little gas permeable. The proliferation of cheaper copper pipework allows moisture in according to my service engineer.
. Cheers, Greg
Post #485059 3rd Aug 2018 11:49am
dingg1
he's blowing smoke up yer arse though
Post #485060 3rd Aug 2018 12:24pm
GGDR
another way of saying it: Chinese copper
Not outside the realms of possibility.
I guy I know knocked out three teeth because his cheap
(i.e. Chinese) mountain bike snapped it's forks.
I'm no metallurgist though.
. Cheers, Greg
Post #485062 3rd Aug 2018 12:50pm
Vogue
Personally I would wait until you notice a difference with the a/c temp and do it when needed 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17
Post #485068 3rd Aug 2018 2:01pm
Given the pressures inside the refrigerant pipework relative to outside air I would have thought any gas migration including moisture would be from the pipework outwards not inwards. Could be wrong though. Thumbs Up
Post #485069 3rd Aug 2018 2:11pm
Page 1 of 3 123>
