Home > Maintenance & Mods (L322) > Windscreen replacement woes |
SidewaysMatt Member Since: 24 Feb 2016 Location: Ledsham, Cheshire Posts: 173 |
So I had a 2" crack in the centre of my screen, and with the MOT looming in a month or 2 decided to get it replaced. My insurers glass cover is operated by Auto Windscreens, so I phoned them to arrange a replacement.
1st Aug 2018 11:11am |
gettingold Member Since: 03 Apr 2018 Location: Wiltshire Posts: 285 |
The rubber bits may settle, especially in the oncoming heat this weekend. The raised bit is probably causing your noise now its in the air flow. With regards the dirt somebody must have signed the job off? = careless. I'd ring them and let them know give it until after the weekend and if still present go back, but you must get that call in or the moment has passed. I had a windscreen change on my RRS1 and the subsequent trim lifting at the bottom around the wipers left a gap which water went in. No real problem but it highlighted the cabin air filter aperture issue and I had a wet foot well = fixed.
1st Aug 2018 3:44pm |
MikeO Member Since: 02 Jan 2018 Location: The Cotswolds Posts: 517 |
When I had mine done at Auto Windscreens, the fitter was complaining that the book time was 90mins but it would actually take him at least twice that and it did. I watched every minute of it and helped him lift the new screen in.
1st Aug 2018 5:03pm |
And no, it shouldn't flap around like that. Just checked mine and I can't even get my finger under it. 2016 Skoda Octavia VRS Estate
1st Aug 2018 5:06pm |
