Home > Maintenance & Mods (L322) > Windscreen replacement woes
SidewaysMatt
United Kingdom 2004 Range Rover Vogue Td6 Giverny Green
So I had a 2" crack in the centre of my screen, and with the MOT looming in a month or 2 decided to get it replaced. My insurers glass cover is operated by Auto Windscreens, so I phoned them to arrange a replacement.
Very helpful they were but insisted that I go to them, rather than they come to me, so not subject to weather etc. Their place was 20 miles away but OK. Was told it would take about 90 mins.
Got there yesterday morning, checked which screen they were fitting; it was a Pilkington one so all good there. Wandered off for 2 hours. Came back, still hadn't got the old screen out. Apparently it wasn't budging, and the fitter had broken cutting line and blades trying to get it out. Anyways, another hour passes and he manages to get it out. Then another hour and the new one is in and good to go. So 4 hours in total.
Driving home, i notice grubby black stains on my ivory A post trims. Oh well, bit of cleaning needed.
However nearly home and I hit 60 mph. And there's a god awful racket coming from round the screen. A mix of loud, badly played pan pipes with the sound of something flapping about.
Had a look around it this morning and taken a few pictures. Firstly, is there supposed to be a seal/trim piece where the top of the screen meets the roof? I could have sworn there was but maybe imagining it. Secondly, the scuttle is supposed to be glued to the bottom edge of the screen isn't it? And lastly, the black A post covers shouldn't flap about should they??!
Video of loose A pillar cover:
https://youtu.be/Ap75wJrvCfw 2004 Vogue TD6 - Remapped Smile
2008 Porsche Cayenne S
1998 Lotus Elise
Post #484900 1st Aug 2018 11:11am
John w
United Kingdom 2011 Range Rover Autobiography Black TDV8 Barolo Black
Hmm, I wouldnt be happy with that Rolling Eyes
I would think the screen should be bonded all the way around, as that is part of the structural integrity.
The roof strips are correctly fitted over the top rubber, the gap at the top doesnt look quite right to me though.
It looks like the screen is either fitted a bit low, or lop sided.
As for the grubby hand prints, thats just careless Crying or Very sad Too many toys, not enough time
2011 4.4 TDV8 AB Black
Post #484902 1st Aug 2018 11:55am
gettingold
The rubber bits may settle, especially in the oncoming heat this weekend. The raised bit is probably causing your noise now its in the air flow. With regards the dirt somebody must have signed the job off? = careless. I'd ring them and let them know give it until after the weekend and if still present go back, but you must get that call in or the moment has passed. I had a windscreen change on my RRS1 and the subsequent trim lifting at the bottom around the wipers left a gap which water went in. No real problem but it highlighted the cabin air filter aperture issue and I had a wet foot well = fixed.
Steve.
Post #484908 1st Aug 2018 3:44pm
MikeO
Scotland 2009 Range Rover Vogue TDV8 Buckingham Blue
When I had mine done at Auto Windscreens, the fitter was complaining that the book time was 90mins but it would actually take him at least twice that and it did. I watched every minute of it and helped him lift the new screen in.
It should be bonded at the bottom. Like you they didn't do mine so I turned around and it took him 30s to put some sealant on there which fixed the noise. 2016 Skoda Octavia VRS Estate
<gone>2009 FF Vogue TDV8 Buckingham Blue</gone>
<gone>2015 BMW 520D SE (not my favourite car)</gone>
<gone>2009 D3 HSE Galway Green</gone>
Post #484924 1st Aug 2018 5:03pm
MikeO
And no, it shouldn't flap around like that. Just checked mine and I can't even get my finger under it. 2016 Skoda Octavia VRS Estate
Post #484925 1st Aug 2018 5:06pm
