Home > Technical (L322) > Hub nut removal
Page 4 of 4 <1234
alfapat
Scotland 2004 Range Rover Vogue Td6 Bonatti Grey
We will see , I guessed you would say that, I am in for a challenge then.
Can I assume that the sensors fitted are still causing the air susp. to be locked , if they are faulty.
so I have moved on from this problem a bit .
After checking out the front reluctor rings (abs) I noticed they were polished and thats not right so IM thinking , the're rubbing on something to do that and due to fact that my abs was registering a plausibility with the diagnostic , I decided to bite the bullet and extract the front driveshaft.
So this has confirmed things for me.
Maybe of use to other threads on the same theme. We will see when all goes back together , will go and order new ones now.
[/img]
Post #484772 30th Jul 2018 10:12pm
Page 4 of 4 <1234
