![]() | Home > Technical (L322) > Hub nut removal |
alfapat Member Since: 09 Apr 2017 Location: Elgin Posts: 349 ![]() ![]() ![]() |
IM SURE THIS IS NOT NEW , Ive done a lot of seaeching online to define the socket for the rear hub nut/driveshaft for 2004 L322 , I have decided it is a 36mm 12pt socket and I need as a 3/4 drive as I think the 1/2 " is going to snap. Can I ask if this is what I am looking for? |
Ok sorted so far , Hub nut off and driveshaft out reluctor ring was left in the hub totally goosed and adrift from driveshaft , now for replacement with new ring
Not pretty |
The hub nut on the end of the driveshaft , 36mm 12pt , has to at leas 3/4 drive , very tight!
Reckon this might do it, with an impact driver and /or some trampoline legs |
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 ![]() ![]() ![]() |
nicedayforit, nice one |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8749 ![]() ![]() ![]() |
just bought me one of these for undoing tricky nuts.......
works wonders ![]() Helps that we have all the batteries etc in the van......Experimented by putting one of my wheel nuts on with a 2' bar with me standing on the end.......whizzed it off no probs. There is nothing that can't be fixed with a hammer😜😜 FFRR 4.4 SDV8 Autobiography Santorini Black. KIA E-Niro 4+ 2021 Discovery 5 D300 MHEV commercial |
its me Member Since: 08 Mar 2013 Location: southampton Posts: 78 ![]() ![]() ![]() |
That will be a very powerfull tool if it will undo the hub nut. I needed a 3/4 breaker bar and a 4 ft. scaffold tube. 2011 4.4 tdv8 Kahn. 2007 supercharged with 2012 lights and overfinch body kit. P38 with a full J.E.Engineering conversion |
A very expensive Ingersol impact I had would not look at it , so yeah 3/4 breaker bar, nut been since new I reckon. I saw the Halfords one , but half inch drive and I already had one.
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 ![]() ![]() ![]() |
Am I right in thinking it’s about 400 Nm? When I did my front one back up I calculated how far along the breaker bar I would need to stand to apply the correct torque as my torque wrench didn’t go high enough. |
Alapat.. You mention the reluctor ring and retainer. What and where is the retainer as I didn't see one. 2011 4.4 tdv8 Kahn. 2007 supercharged with 2012 lights and overfinch body kit. P38 with a full J.E.Engineering conversion |
Yes it’s 410nm , that’s too complicated for me to work out , I will have to borrow the one from work, or as some of my friends say “Pat tight”. Alright , the abs rings I bought comes with a fluid in a bottle called retainer , it’s specially formulated to hold the ring in place on a cold fitting. I asked the company do I heat the ring then fit it , but no. In any case there has been so much corrosion that heating the ring to expand it to fit would be pointless, and as I don’t know what the real diameter of a new one is I’m not sure how tight they are made to originally. So when my driveshaft was prepared to accept the new ring I had at any given gap about 1/2 mm and that I think would be the maximum this retainer fluid would tolerate. Loctite do something similar, Retainer and bearing fit for worn shafts . Well I now see how it works, looking at the nearside now off it doesn’t look quite so eaten away, but still fell off the shaft when I finally got it out . I will take a couple of pics to show then and now later today. Uploaded above. |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1808 ![]() ![]() |
Getting the hub nut off is the easy part.
^^^^supposed to have "Up to 1625Nm of "breakaway" torque ensures removal of the tighest bolts".......... There is nothing that can't be fixed with a hammer😜😜
