Home > Maintenance & Mods (L322) > [SOLVED] Errors from 2010-2012 Rear Lights
My 2008 / MY2009 car came fitted with later 2010-2012 rear lights
Issues:
On every start up, on first use of indicators, both sides, they flash really quickly then settle down. Subsequent use is normal
With lights on, I get intermittent faults on the message centre to "check tail light", "check rear side light".
iiDTool is registering faults with both rear indicators.
Have had a rear sidelight off, seems I have standard connectors, no interference or additions.
Resolution:
Guessing I need some ballast resistors / other kit to over come all of this. What is it that I need ?
{EDIT} - adjusted to reflect correct lights as per stan's post below .
Post #484512 28th Jul 2018 11:37am
those are standard 2010-2012 rear lights Tim...
there is this from the wiki which refers to 'wiring boxes'
http://www.fullfatrr.com/forum/topic9647.html ... - .- -.
Post #484516 28th Jul 2018 12:08pm
Ah - now I know what I am looking for. Seems this is the module required:
https://www.powerfuluk.com/range-rover-l32...-cars.html
Not exactly plug and play! And I note from the video that it doesn't fix the first start quick flashing of indicators .
Post #484522 28th Jul 2018 12:33pm
i think another way is to tap into the towbar wiring...do a search you lazy git Mr. Green Wink ... - .- -.
Post #484523 28th Jul 2018 12:38pm
Nah just too lazy Cool .
Post #484526 28th Jul 2018 12:43pm
Laughing Thumbs Up ... - .- -.
Post #484527 28th Jul 2018 12:44pm
Not seen the disco lights on startup, nor the fog light coming on.
Maybe just turn off hot/cold monitoring with the iiDTool ? - if I can... .
Post #484530 28th Jul 2018 1:14pm
you should be able to .. ... - .- -.
Post #484534 28th Jul 2018 1:21pm
mjdronfield
I figured if you turned off what hot and cold monitoring you could, you might be left with less issues to resolve....
Some of the ballast resistor stuff gets reall hot and you have to be careful where you put them. You prob know all that already.....
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #484538 28th Jul 2018 2:17pm
PowerfulUK offer 15ohm resistors to stop the hyperflashing of indicators
https://www.powerfuluk.com/vehicles/range-...r-x-2.html
Would 15 ohm also do for the tail light fault messages ? .
Post #484962 1st Aug 2018 10:20pm
Just turn off the hot & cold monitoring to all the rear lights and that will resolve all the flashing and errors Thumbs Up
What happens with your rear fog lamps when you turn them on/off?
Post #484965 1st Aug 2018 11:23pm
tb10
England 2005 Range Rover Vogue 4.4 V8 Tonga Green
I agree with Craig. I did just that and have no issues.
Regards
John
Post #484966 1st Aug 2018 11:33pm
John w
United Kingdom 2011 Range Rover Autobiography Black TDV8 Barolo Black
Joe,
a quick reply from an electronics techie, mainly for future reference.
the link you provided to the resistors shows 15 ohm 25watt.
In practice a normal indicator lamp draws roughly 1.75 amps (21w/12v) at 50% duty cycle (only on 1/2 the time).
A 15 ohm resistor will draw half that 12v/15r = 0.8A), which is enough for the indicator circuit to think a lamp is present.
At a 50% duty cycle that resistor is sinking less than 5watts, and is unlikely to get very warm at all, even if you had your indicators on permanently (similar to a 5w number plate lamp).
Using the same logic for your tail lights, the resistor will be on full time, draw twice the current, and will heat up, but not by a huge amount.
If you can clip or bolt it to the car metalwork somewhere it will sink the heat and not cause an issue.
If you leave it in free air with plenty of air around it, it will probably be ok.
If you enclose it, or tie wrap it to the rear of the plastic tail lights, you might have an issue.
With respect to these resistors, they are about £2.55 each from RS Components. Too many toys, not enough time
2011 4.4 TDV8 AB Black
Post #484978 2nd Aug 2018 7:58am
Thanks all. Got some config and testing to do Thumbs Up
Will report back .
Post #485015 2nd Aug 2018 6:03pm
Got wife and son to stand front and rear whilst I switched on and ran through light sequences.
We couldn't make the rear lights dance, nor the fog light to come on, so these are not the issue.
Turned off just hot monitoring on all the indicator lights, this made them flash fast all the time Evil or Very Mad so restored hot monitoring to on. Maybe turning off hot and cold monitoring together will do the trick ?
Turned off hot monitoring to tail and brake lights, but forgot to test. Not needed to drive with lights on, so haven't!
More to follow.... .
Post #485415 7th Aug 2018 5:26pm
