![]() | Home > Maintenance & Mods (L322) > [SOLVED] Errors from 2010-2012 Rear Lights |
Tested tail lights today, 1/2 hour drive to work with full lights on, same journey back with just sidelights on, no fault messages, so looks like the turn off of hot monitoring has worked for that.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35633 ![]() ![]() |
have you tried switching off cold monitoring to solve that? ... - .- -.
Next job, H+C monitoring off to test on indicators .
Sorted - All H+C monitoring set to NO for front and back and side.
Rosco Member Since: 20 Jan 2012 Location: Beyond the wall. Posts: 2588 ![]() ![]() ![]() |
Yes Stan however it would all depend on the speed/velocity of the yes/no. |
Woofster Member Since: 12 Jul 2018 Location: Toronto Posts: 121 ![]() ![]() |
Did setting all hot and cold monitoring to NO resolve the brief quick flashing of the turn signals upon initial use? |
Yes, as per my post a little way back |
verydisco Member Since: 10 Dec 2009 Location: UK/US Posts: 2952 ![]() ![]() ![]() |
I gather your 322 only has the REAR 2009-on lights then, not the front. This will do the trick indeed then, but if you have the front conversion done, there would be more to it. ![]() Current RANGE ROVER Vogue 4.4L SDV8 - 2013 - Indus Silver, on Almond. RANGE ROVER Vogue 4.4L V8 - 2002 - ex-2003 G4 Challenge Event Vehicle, Stage 3: Australia RANGE ROVER HSE 4.4L V8 - 2004 - one-of-one Overfinch RANGE ROVER P38a 4.0L V8 - 1999 - ex-2000 TReK Event Vehicle: South Africa Previous: RANGE ROVER Vogue 4.4L TDV8 - 2012 - RANGE ROVER 3.6L TDV8 x3 - RANGE ROVER Td6 x1 - RANGE ROVER Classic 3.5L V8 x1 |
As per thread title: Errors 201-2012 REAR lights |
Chlorothalonil Member Since: 08 Sep 2018 Location: East Yorkshire Posts: 53 ![]() ![]() ![]() |
Could anyone tell me how I can stop the fog lights coming on with the tail lights as the Powerful UK board causes the latter to flicker slightly when fitted, albeit it seems to solve the fog issue? Thanks. |
