Home > Technical (L322) > Ticking noise from front trim when door opened lasts about a
horsedentist
United Kingdom 2002 Range Rover Vogue Td6 Giverny Green
My car has developed a ticking from some where behind the front trim panel. It happens when you open any of the doors lasts for approx a minute then stops sounds like a relay try to latch. Once it’s stoppef you can get in and out as many times as you like without it reoccurring. However if you leave the car for about half an hour and go back to it open the door and it does it again. Any clues??
Post #484419 26th Jul 2018 10:56pm
SidewaysMatt
United Kingdom 2004 Range Rover Vogue Td6 Giverny Green
Mine started doing the same last month. It's the AC blend motor behind the trim panel next to your left leg (assuming in the drivers seat).
I got one second hand off ebay for a tenner. BMW part #6917943.9 (ECB515).
It's currently sitting on my desk in front of me, keep meaning to go out there and pop the panel off and swap it out (apparently it's easy accessible when the panel is off) 2004 Vogue TD6 - Remapped Smile
2008 Porsche Cayenne S
1998 Lotus Elise
Post #484450 27th Jul 2018 1:45pm
horsedentist
Many thanks will have a look
Post #484455 27th Jul 2018 2:48pm
horsedentist
Just checked and you are spot on it’s sitting there ticking away. Easy to get to but can’t see how it is attached there is one screw at the bottom off to the right but can’t see what holds it in place at the top.
Post #484461 27th Jul 2018 5:28pm
SidewaysMatt
If you mean the trim, then yes remove that screw at the bottom, then grab the trim at the front and pull towards the driver's door 😀 it's just held on with plastic poppers. 2004 Vogue TD6 - Remapped Smile
1998 Lotus Elise
Post #484517 28th Jul 2018 1:17pm
horsedentist
No I meant the actual unit appears to only have one retaining screw but seems stuck at the top.Just had another look there is an inexcusable screw at the top behind the trunking why do they make things so difficult 😡
Post #484518 28th Jul 2018 1:19pm
SidewaysMatt
OK you've actually prompted me into replacing mine Laughing
So here's a quick how to:
Remove the torx screw for the centre console side panel (drivers side). Once removed, grab hold of the wood bit at the front of the panel and pull towards the drivers door. Panel is held on by poppers and will pop off:
You can now see the offending motor. See what you mean about the screw, but you don't need to remove it. Theres a little plastic tab on the motor (arrowed). Push that in towards the body of the motor and pivot the bottom edge of the motor out of it's mounting:
You can see the tab more clearly in this photo after the motor is removed:
Swap the wiring onto the new motor then refit by slotting top edge of the motor in first, then pivot the bottom in until the tab / latch thing clips into place. Refit dash panel. Job done. Takes about 10 mins all in. 2004 Vogue TD6 - Remapped Smile
1998 Lotus Elise
Post #485056 3rd Aug 2018 12:31pm
horsedentist
Thanks for that I did consider that but thought it might bust something as I was sure there would be more holding it in place. I have ordered a replacement off eBay just waiting for it to be delivered and I will pop it in.
The ticking is annoying isn’t it.
Post #485075 3rd Aug 2018 4:20pm
horsedentist
Unnecessary quote removed
Popped mine out took cover off no damaged cogs put it back together now running smoothly was just stuck it seems. Have another on order so will change it when it arrives just in case.
Post #485113 3rd Aug 2018 9:16pm
SidewaysMatt
Result. Yes the noise was driving me mad! 2004 Vogue TD6 - Remapped Smile
1998 Lotus Elise
Post #485116 3rd Aug 2018 10:09pm
Dustbolt
United Kingdom 2005 Range Rover Supercharged 4.2 SC V8 Santorini Black
Good post, I have the same thing to fix.
Does anyone know if the various 515, 516 etc variants of the part are interchangeable ? Here is my one:
I have found one on ebay that looks identical, is also ECB515, but BMW part number is a bit different (but quite close).
Just wonder if those who have successfully replaced this matched with identical parts or whether ECB516, ECB515 etc are interchangeable - or there is some odd difference - eg fittings are different...?
Many thanks in advance...
Post #499409 22nd Dec 2018 11:42am
horsedentist
Before you buy a new one have a look at the old one I prised the cover off and it was full of crap. I cleaned it with some wd40 gave it a good flush out then sprayed it with silicone oil. Been working fine ever since.
Obviously if any of the teeth are worn it will need replacing but mine was fine just stuck.
Post #499416 22nd Dec 2018 1:39pm
Dustbolt
thanks - I will try that first...
Post #499420 22nd Dec 2018 2:09pm
Dustbolt
I got around to doing this and as suggested I tried servicing the existing motor rather than just buying another. It's actually quite straightforward to do - the motor unclips (by pressing on the release, no unscrewing required). And then the motor itself can be carefully prised open - its in 3 parts, by taking off the back you can clear out any fluff etc and then apply some wd40. Once it was all free moving put it back in.
When putting it back in, it's easier to fit the base and then the top in order to slot the lever back in place.
Post #500260 1st Jan 2019 5:45pm
jfarrell32
Ireland
Hi, hi the same problem and just curious what function this motor performs. Rgds, J
Post #549120 1st Apr 2020 9:52pm
