Home > Technical (L322) > Ticking noise from front trim when door opened lasts about a |
SidewaysMatt Member Since: 24 Feb 2016 Location: Ledsham, Cheshire Posts: 173 |
Mine started doing the same last month. It's the AC blend motor behind the trim panel next to your left leg (assuming in the drivers seat).
27th Jul 2018 12:45pm |
horsedentist Member Since: 23 Jun 2017 Location: london Posts: 158 |
Many thanks will have a look |
27th Jul 2018 1:48pm |
Just checked and you are spot on it’s sitting there ticking away. Easy to get to but can’t see how it is attached there is one screw at the bottom off to the right but can’t see what holds it in place at the top. |
27th Jul 2018 4:28pm |
If you mean the trim, then yes remove that screw at the bottom, then grab the trim at the front and pull towards the driver's door 😀 it's just held on with plastic poppers. 2004 Vogue TD6 - Remapped
28th Jul 2018 12:17pm |
No I meant the actual unit appears to only have one retaining screw but seems stuck at the top.Just had another look there is an inexcusable screw at the top behind the trunking why do they make things so difficult 😡 |
28th Jul 2018 12:19pm |
OK you've actually prompted me into replacing mine
3rd Aug 2018 11:31am |
Thanks for that I did consider that but thought it might bust something as I was sure there would be more holding it in place. I have ordered a replacement off eBay just waiting for it to be delivered and I will pop it in.
3rd Aug 2018 3:20pm |
Unnecessary quote removed
3rd Aug 2018 8:16pm |
Result. Yes the noise was driving me mad! 2004 Vogue TD6 - Remapped
3rd Aug 2018 9:09pm |
Dustbolt Member Since: 09 Dec 2018 Location: London Posts: 12 |
Good post, I have the same thing to fix.
22nd Dec 2018 10:42am |
Before you buy a new one have a look at the old one I prised the cover off and it was full of crap. I cleaned it with some wd40 gave it a good flush out then sprayed it with silicone oil. Been working fine ever since.
22nd Dec 2018 12:39pm |
thanks - I will try that first... |
22nd Dec 2018 1:09pm |
I got around to doing this and as suggested I tried servicing the existing motor rather than just buying another. It's actually quite straightforward to do - the motor unclips (by pressing on the release, no unscrewing required). And then the motor itself can be carefully prised open - its in 3 parts, by taking off the back you can clear out any fluff etc and then apply some wd40. Once it was all free moving put it back in.
1st Jan 2019 4:45pm |
jfarrell32 Member Since: 23 Sep 2014 Location: Straffan Posts: 25 |
Hi, hi the same problem and just curious what function this motor performs. Rgds, J |
1st Apr 2020 8:52pm |
