Home > Technical (L322) > Ticking noise from front trim when door opened lasts about a
GUMBALLER
United Kingdom 2002 Range Rover Vogue 4.4 V8 Java Black
An old post I know but I have this ticking noise when I first open the doors. I’ve removed this motor and ordered a new one.
Surprisingly with the motor removed the ticking still occurs. Is this normal?
Thanks
Post #643526 21st Sep 2022 5:28pm
horsedentist
United Kingdom 2002 Range Rover Vogue Td6 Giverny Green
I stripped mine down cleaned and greased it put it back in and resolved the problem I did buy another eventually and kept my refurbed one as a spare. Don’t think it should click without the motor in place but I am no expert and never tried mine without the motor. It’s just the gears jammed up inside the casing mine was full of fluff and gunk.
Post #643537 21st Sep 2022 7:03pm
GUMBALLER
I assumed no motor no ticking, but not the case.
Post #643550 21st Sep 2022 8:12pm
Rudyard1
What about a bit of thread resurrection?! Started happening to mine - took that little motor/gearbox out - still clicking in same region. Any ideas collective wisdom lenders?! 2007 Range Rover Vogue 3.6 TDV8
Post #697169 30th Jul 2024 8:51pm
Scottyav
United Kingdom 2007 Range Rover Autobiography TDV8 Zambezi Silver
I’m about to look at mine tomorrow as it’s not letting any heat into the car and clicking, I’m hoping it’s this and that it will fix the issues. I have got a friend that has one that I can try but I will try and clean it out and check first then post any news. _____________________________________________________
Zambezi silver Vogue Se unique Smile
Post #701427 4th Oct 2024 12:53am
Scottyav
Ordered the water valves and solenoid for under the bonnet, hot pipe in but cold coming out so looks like it’s that, just over 20quid on eBay https://www.ebay.co.uk/itm/363867063367?mk...media=COPY _____________________________________________________
Post #701686 7th Oct 2024 8:19am
