![]() | Home > Maintenance & Mods (L322) > Preventative maintenance for turbos |
Laurie915 Member Since: 11 Sep 2011 Location: Canberra Posts: 72 ![]() ![]() ![]() |
Use the best synthetic oil and filter available, change the oil and filter when it appears to deteriorate, not by mileage. Use a EGR System cleaner like Revive every 80,000km I now also use a de-carboniser additive in our diesel fuels, wife has a TDI Skoda VSR. Different driver styles and trip types have a big influence on the engine oils.Short trips will have a big effect on oil life, especially if full operating temperatures are not reached.
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6419 ![]() ![]() |
Good advice Laurie, but will this have any impact , that is the EGR cleaner, if it has not been used so far on a 100K + motor? If the EGR's are likely to already be quite carbonised, will a cleaner cause more harm than good ? .
Rapiscan Member Since: 28 Apr 2018 Location: North Lincolnshire Posts: 182 ![]() ![]() ![]() |
Thanks Laurie. I should have mentioned both egr valves were replaced with new ( I have the garage receipt , Land Rover Indy specialist )some 4 months before I bought it, so I’m hoping the turbos were ok before the old valves went west! I also have a stamped up service book, which appears to show a full service history.These cars get me,we drive em with clenched buttocks,bated breath in a cold sweat |
Provarmint Member Since: 16 Aug 2017 Location: Warrington Posts: 76 ![]() ![]() ![]() |
Ha ha, like the last statement. |
Personally I believe that it could only benefit the engine if done correctly and the other minor maintenance carried out eg lubricate actuators etc. Below are comments I posted on the AURLO site in regards to the turbo's.
The missing pic.
A better sized image |
Ouch! I’m gonna have to sell one of me kidleys or possibly both on eBay so I’ve got the necessary funds when mine go all curly! |
[quote="Joe90"]A better sized image |
How it all works (but no mention of turbos)
Great informative video! Thanks! Has anybody fitted a bypass filter yet? What does it involve,degree of difficulty and cost etc?Where did you obtain it and what make also? Thank you .. |
I am coming to the conclusion that, given we have +100K mileage cars, the best thing to do is:
rar110 Member Since: 09 Aug 2014 Location: Brisbane, Australia Posts: 1119 ![]() ![]() ![]() |
I also use revive. I think it help the intake system. It might help remove those deposits on turbo fan blades and reduce the risk of an imbalanced CHRA. Induction cleaner leaves the hot turbo pretty much as steam and flows through the intercooler intake pipes and manifold, inside the head and combustion chamber, through the exhaust side of the turbo, a small amount through the EGRs but most out the exhaust. Taking soot and grime out of the engine.
Has anyone used Forte turbo cleaner? |
