Home > General > FFRR less
RRRob
United Kingdom 2004 Range Rover Vogue Td6 Cairns Blue
FFRR less
I am currently Range Roverless ,its not a pleasent feeling seeing it disapeer on the back of a recovery truck. Big Cry
I had the transmission failure that most TD6's suffer , this morning on the way into work.
The transmission apparently can disintergrate from 80k onwards so I suppose 119k is a good innings.
Its having a recon box and torque converter fitted and hopefully will have it back by monday.
Post #48363 1st Feb 2011 1:15pm
Jem0911
United Kingdom 2015 Range Rover Vogue SE SDV8 Corris Grey
Feeling that pain,
Kepp us informed on progress. 15MY SDV8 Vogue SE
Post #48364 1st Feb 2011 1:22pm
GregP
United Kingdom 2002 Range Rover HSE Td6 Adriatic Blue
sad news.
I have been without mine for over 2 weeks now. Having some work done under warranty. Picking it up this afternoon which is ideal Smile
Are there any signs to look out for when the transmission is close to going?? FFRR TD6 HSE
Adriatic Blue with Parchment leather.
Post #48365 1st Feb 2011 1:26pm
elpeede
England 2003 Range Rover Vogue Td6 Zambezi Silver
In my case I nearly had a healthy bank balance... which always a sign of some kind of impending doom.
All sorts of different failures so hard to pin it down to individual symptoms. 2010 Disco XS TDV6, 2009 Freelander 2 GS
Previous Landrover products -1990 110 TDI CSW, 2003 TD6 Vogue - RRC TD Vogue, RRC v8 Fleetline, Disco ES V8 LPG, 101 Ambulance "Morph", 1964 SIIa Auto Powered by Jag 4.2 Lump - "Percy".
Post #48366 1st Feb 2011 1:42pm
GregP
lol, I should be ok then as my bank balance is never healthy Smile FFRR TD6 HSE
Post #48369 1st Feb 2011 2:45pm
Dolphinboy
RRRob, had you ever had your gearbox oil and filter changed at all? I am at 90k now and thinking about having mine done.
Post #48370 1st Feb 2011 2:53pm
RRRob
Hi the signs with mine have been .............
Hesiatant to change up ,holding on to gears to long.
Slow to pick up when accelerating away from rest especially when cold.
A general feeling of "unsmoothness".
I suppose its been in the back of my mind for the last 10k miles or so that things didn't feel quite right.
Up until I started lurking and subsequently joining on here I thought it was a sealed for life unit as Landrover say it is, the posts from people on here brought to my attention that it is not and that transmission fluids and filters should be changed regular.
Dolphinboy I wouldn't know what to suggest for a motor with 90k on it , do you spend out for a fluid change etc with the risk that potentially the day after the transmission failing.
How much more life a fluid change would give your transmission I dont know.
Perhaps bank the cost and put it towards the £1600-2000 cost of a replacement transmission that you will need. Are you keeping the RR for a while yet or planning on changing it ? that is another factor in what you do.
I am planning on keeping mine for a good few years yet as I will never be in the position to trade up to another FFRR so the expense of the repair is better to take as I will be reaping the rewards for many miles in the future.
So at the moment the drive is empty and the FF at the menders . Its an odd feeling Confused
Post #48380 1st Feb 2011 4:11pm
Dolphinboy
Thanks for that RRRob. I have to say mine is running "sweet as" Whistle but the box filter and oil change is only a couple of hundred of spuds and local. Dan_1984_uk had his done there so I know it's good!
Reckon mine is gonna be a keeper as it's not put a foot wrong in nearly 2 years and has everything I need (although a 3.6 or 4.4 TDV8 engine would be nice!)
anyone had theirs done and if so what was the cost?
Post #48384 1st Feb 2011 4:35pm
elpeede
Figures are tattooed on the insides of my eye lids.. so I can see them while I'm asleep! Twisted Evil
Fluid and filter changed £140
Then eventually full box strip down and rebuild everything you can £2920 (including the output shaft to the transfer box)
Both by well reputed local specialists in autos. Ooo that reminds me.. need to book it in for its 1000 mile look over, just to check their are no leaks etc.. which there aren't but the select cable could do with a slight minor adjustment, no biggy. 2010 Disco XS TDV6, 2009 Freelander 2 GS
Post #48392 1st Feb 2011 6:59pm
mzplcg
The thing with autoboxes is that the fluid does deteriorate and when it does it contaminated valves, internal oilways and brake bands etc. This can only serve to shorten the life of the box. Sticky valves make for hesitant changes etc.
Think about the engine for a moment. If you never changed the oil then the engine would have a markedly shorter life, yes?
Yes it's different oil and yes it does a different job but the principles of contaminated fluid are fairly constant. If it makes all the internals of the box work harder then the service life will be shortened. Burnt fluid contains lots of contaminants which are not caught by the strainer. Lots of referrals to the 'filter' but it is only a strainer in reality and is not designed to filter down to the same level as the engine oil filter. Again, think about the engine; it has a strainer on the oil pickup in the sump and then it has a filter as well. The box does not.
Thinking about the ZF 6 speed which LR claim to be sealed for life, well I've had 2 cars with this box, one which I left as it was and one which I had megaflushed. I know which was the better box at 90k miles.
If it was mine I'd spend the 200 quid and get the fluid changed. Won't do any harm and will very probably increase the life of the box by a big margin.
Post #48395 1st Feb 2011 7:15pm
dan_uk_1984
I agree with above, of course as most of it I have already said in various previous posts.
The manufacturer recommends changing the oil at 50K, if you run it to 100K you shouldn't be surprised if you have a failure.
This isn't helped by the "filled for life" stance LR have - however what they mean is "life of the warranty" They WANT you to be back in 5+ years time for a new gearbox. It's a good profit to them, compared to the lower margins on the cars themselves.
Post #48409 1st Feb 2011 8:05pm
RRRob
Its back Very Happy Very Happy
All seems as it should be, I also notice the MPG seems to have risen as well, considerably. I will monitor over the next week and get an exact figure through the pump rather than the on board computer.
Post #49214 7th Feb 2011 1:08pm
comports
United Kingdom 2016 Range Rover Autobiography SDV8 Mariana Black
Is there a "how to" on changing the trans fluid on a TD6 somewhere and is it possible to do without ramps/lifts.
I'de happily undertake it myself if was a diy job one weekend. Mines on 48K now so best to keep it in tip top shape. Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #49241 7th Feb 2011 4:38pm
It's not a big job but you need to raise the vehicle to remove the gearbox sump
Post #49245 7th Feb 2011 4:45pm
RRRob
Here is the link to the oil change.
http://www.fullfatrr.com/forum/topic1259.html
Yes keeping on top of the job is a must, if you can diy cool.
Post #49247 7th Feb 2011 4:59pm
