![]() | Home > General > FFRR less |
Jem0911 Member Since: 07 Jan 2010 Location: East Northants Posts: 357 ![]() ![]() ![]() |
Feeling that pain,
GregP Member Since: 11 Dec 2010 Location: Exmouth Posts: 1084 ![]() ![]() ![]() |
sad news.
elpeede Member Since: 09 Mar 2010 Location: Staffordshire Posts: 713 ![]() ![]() ![]() |
In my case I nearly had a healthy bank balance... which always a sign of some kind of impending doom. All sorts of different failures so hard to pin it down to individual symptoms. 2010 Disco XS TDV6, 2009 Freelander 2 GS Previous Landrover products -1990 110 TDI CSW, 2003 TD6 Vogue - RRC TD Vogue, RRC v8 Fleetline, Disco ES V8 LPG, 101 Ambulance "Morph", 1964 SIIa Auto Powered by Jag 4.2 Lump - "Percy". |
lol, I should be ok then as my bank balance is never healthy ![]() Adriatic Blue with Parchment leather. |
RRRob, had you ever had your gearbox oil and filter changed at all? I am at 90k now and thinking about having mine done. |
RRRob Member Since: 24 Jul 2010 Location: Bury Posts: 123 ![]() ![]() ![]() |
Hi the signs with mine have been .............
Thanks for that RRRob. I have to say mine is running "sweet as" |
Figures are tattooed on the insides of my eye lids.. so I can see them while I'm asleep! |
The thing with autoboxes is that the fluid does deteriorate and when it does it contaminated valves, internal oilways and brake bands etc. This can only serve to shorten the life of the box. Sticky valves make for hesitant changes etc.
I agree with above, of course as most of it I have already said in various previous posts.
Its back |
comports Member Since: 20 Dec 2010 Location: Colchester Posts: 1748 ![]() ![]() ![]() |
Is there a "how to" on changing the trans fluid on a TD6 somewhere and is it possible to do without ramps/lifts.
It's not a big job but you need to raise the vehicle to remove the gearbox sump |
Here is the link to the oil change.
