![]() | Home > Technical (L322) > Air Conditioning No Power to Compressor |
Johnsd1v8 Member Since: 06 Jul 2017 Location: Cheshire Posts: 190 ![]() ![]() ![]() |
On my l322 mate there is a couple of fuses for ac there on left side just below cd changer in glove box the fuse pannel has a list of what fuses do what have a look in there |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6419 ![]() ![]() |
On '02 and '09 it is fuse 12 - 10amp (most likely) then fuse 34 - 7.5amp, so probably the same on yours.... |
Same as mine that ye mines a 54 reg |
Stanley Member Since: 23 Jan 2016 Location: Warwickshire Posts: 22 ![]() ![]() |
Thanks all for your guidance. I finally found the fuse int eh passenger compartment F62 10 amp on the 2011 TDV8. It was labelled climate control ECU and I was looking for AC. Anyway checked it and it's fine so not the problem.
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3259 ![]() ![]() ![]() |
Just a thought, is the "air con" button on the control panel illuminated? John
Yep and AC Max button works as well. 2011 TDV8 Vogue
With the air con switched on, and engine running, get a view of the compressor. Is the end of the compressor going round, or just the grooved ring on the belt? If it is, then clutch should be engaged ( |
Thanks for the guidance. I assume that the compressor is on the bottom right of the engine block as I stand in front of the car? (pic enclosed) The end of the compressor does indeed turn but irrespective of whether or not the AC button is on or off! Is that correct?
John w Member Since: 14 Jan 2018 Location: Cranleigh, Surrey Posts: 439 ![]() ![]() ![]() |
Stanley, I have experienced exactly the same this last week.
I've just read the other aircon thread.
John W.
If you have a halford nearby ask about their 40 quid recharge. The first thing they should do is check the low pressure side pressure, as that is the side they inject the additional gas.
Going to be tied up until until I have it booked in. I'll post the outcome.
So got it to the electrical/air conditioning specialist and the assessment is the the AC compressor is toast. Checked the gas level-ok. Did a climate control read -no faults logged. Carried out further tests and conclude that the drive plate is faulty. The clutch on teh front of the compressor is always engaged even when the AC switch in the cabin is not activated.
