Home > Technical (L322) > Air Conditioning No Power to Compressor
I would hazard a guess at @ 2 hours labour. Took me a leisurely 3.5 hours to swap out an AC compressor on a TD6 (first time of doing it) but this was with an empty system so I didn't have to extract gas / do vacuum etc. That will come on top.
Best to get the tensioner and pulley checked over too.
My compressor seized, and shredded the belt. .
Post #483919 20th Jul 2018 4:33pm
John w
United Kingdom 2011 Range Rover Autobiography Black TDV8 Barolo Black
Hi Stanley,
Yep, my compressor appears to have the clutch permanently engaged too.
I initially thought this was a problem but I am not convinced now, as the later compressors on ours dont seem to have a magnetic clutch (I am unclear on this, so may be wrong until I can check properly).
It does get cold as I reported before (low pressure pipe behind top of rad), just not as cold as I expected.
A new OE compressor from LR is ~£1200 Shocked
A new one from elsewhere is sub £300. By contrast the valve previously discussed is £120 from LR, or half that if bought elsewhere.
I havent had time to dig into this yet, but do intend to, so would be great to hear how you get on. Too many toys, not enough time
2011 4.4 TDV8 AB Black
Post #484142 23rd Jul 2018 12:38pm
