Home > Technical (L322) > Air Conditioning No Power to Compressor
Stanley
Aircon wasn't really very cold so took it for a regas. Gas volume down a little but topped up. Aircon guys said that there was no power at the compressor (clutch?) Been checking for fuses associated with aircon but owners handbook doesn't list any.
Anybody point me in the right direction?
TIA 2011 TDV8 Vogue
1996 4.6 HSE
Post #482989 9th Jul 2018 3:38pm
Johnsd1v8
United Kingdom 2004 Range Rover Autobiography Td6 Zambezi Silver
On my l322 mate there is a couple of fuses for ac there on left side just below cd changer in glove box the fuse pannel has a list of what fuses do what have a look in there
Post #483070 10th Jul 2018 7:22am
On '02 and '09 it is fuse 12 - 10amp (most likely) then fuse 34 - 7.5amp, so probably the same on yours.... Question .
Post #483137 10th Jul 2018 8:20pm
Johnsd1v8
Same as mine that ye mines a 54 reg
Post #483144 10th Jul 2018 8:59pm
Stanley
Thanks all for your guidance. I finally found the fuse int eh passenger compartment F62 10 amp on the 2011 TDV8. It was labelled climate control ECU and I was looking for AC. Anyway checked it and it's fine so not the problem.
Had along drive yesterday and whilst the AC seems to function fine it just doesn't get very cool. A couple of times on the run it actually warmed up a noticeable amount. Anyone experience this before?
TIA 2011 TDV8 Vogue
1996 4.6 HSE
Post #483163 11th Jul 2018 7:56am
Weegie
Just a thought, is the "air con" button on the control panel illuminated? John
GAP iiD BT
Post #483164 11th Jul 2018 8:18am
Stanley
Yep and AC Max button works as well. 2011 TDV8 Vogue
1996 4.6 HSE
Post #483165 11th Jul 2018 8:26am
With the air con switched on, and engine running, get a view of the compressor. Is the end of the compressor going round, or just the grooved ring on the belt? If it is, then clutch should be engaged ( Thumbs Up ), and may be worth going back for a regas/pressure check. If it is not going round, could be not enough gas / pressure again in order to get the clutch to engage. .
Post #483183 11th Jul 2018 12:06pm
Stanley
Thanks for the guidance. I assume that the compressor is on the bottom right of the engine block as I stand in front of the car? (pic enclosed) The end of the compressor does indeed turn but irrespective of whether or not the AC button is on or off! Is that correct?
I'm familiar with the AC clutch on my P38 and that clearly does click in and out when AC is requested and it doesn't seem to do that.
I had no leaks found when tested and the gas was just topped up a little to fill it up.
Any further thoughts?
Thanks again.
 2011 TDV8 Vogue
1996 4.6 HSE
Post #483189 11th Jul 2018 12:39pm
John w
United Kingdom 2011 Range Rover Autobiography Black TDV8 Barolo Black
Stanley, I have experienced exactly the same this last week.
It blows cool, just not ice cold.
I know (or at least think) it works as the low pressure side pipework gets noticeably chilled when it is switched on, and this is after the pipework was almost too hot to touch after a drive with it switched off.
Just back from having the aircon re-gassed.
The guy drained the gas (only had 740mg), did a 30 minute vacuum check, dye added, re-oiled and re-gassed (880mg).
After all this the pipe still gets chilled but its not much difference cold air wise in the car.
He didnt charge me for doing it as its not made any/much difference, which is nice but doesnt make me any cooler Confused
My compressor is definitely going around, and as I say the low pressure (thick) pipe gets cool.
It does seem to me that the ecu is doing something weird, as sometimes it works a treat, and then others it is just slightly chilled, not fecking cold like I would expect it to be. Selecting Max Aircon just seems to make the fans run flat out and use recirculation, not get any colder.
I'm going to take the filter out to see if that makes any difference to it.
What do the 2 leds mean on the recirc button ?
Is one front and one rear ? (my car has front and rear aircon)
Hmm, that raises a question - I wonder what the temp is like in the back, must try that...
Anyway, if you find the solution to this please let me know before I melt Embarassed Wink Too many toys, not enough time
2011 4.4 TDV8 AB Black
Post #483190 11th Jul 2018 12:41pm
John w
I've just read the other aircon thread.
Funnily enough I first went to h@lfords for a top up, and the guy told me the low pressure side was over pressure, which is why I wentto have it properly recharged.
So it sounds like I have the sticky valve problem.
Maybe yours is the same stanley, get the low pressure side checked and see what it says. Too many toys, not enough time
Post #483194 11th Jul 2018 12:51pm
Stanley
John W.
Sounds as though we have a very similar problem! Just checked mine and same as you, the thick pipe is going nice and cold. Air did seem cooler in the cabin but still not cold.
Got it booked into my local AC shop but they can't look at it until Friday week! Still we need some rain for the garden!!
I'll report back on what they find.
Stanley 2011 TDV8 Vogue
1996 4.6 HSE
Post #483200 11th Jul 2018 1:11pm
John w
If you have a halford nearby ask about their 40 quid recharge. The first thing they should do is check the low pressure side pressure, as that is the side they inject the additional gas.
If it is over pressure they should not do it.
If they do add gas and it makes no difference, they should not charge you (its in their terms).
Has to be worth a shot, you dont even need to book as long as its not a peak time Wink Too many toys, not enough time
Post #483202 11th Jul 2018 1:16pm
Stanley
Going to be tied up until until I have it booked in. I'll post the outcome.
Thanks for all the assistance. Much appreciated. 2011 TDV8 Vogue
1996 4.6 HSE
Post #483211 11th Jul 2018 3:21pm
Stanley
So got it to the electrical/air conditioning specialist and the assessment is the the AC compressor is toast. Checked the gas level-ok. Did a climate control read -no faults logged. Carried out further tests and conclude that the drive plate is faulty. The clutch on teh front of the compressor is always engaged even when the AC switch in the cabin is not activated.
Anyone seen this before? Have requested estimate for replacement. Sounds as though compressor is about 400 pounds. Anybody have any idea about the amount of labour needed?
Thanks in advance.
S 2011 TDV8 Vogue
1996 4.6 HSE
Post #483917 20th Jul 2018 4:15pm
