![]() | Home > Wheels & Tyres > 255 50 20 or 275 45 20? |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3552 ![]() ![]() ![]() |
Check this: http://www.fullfatrr.com/forum/topic47398.html Cheers, Greg
Paul thornton Member Since: 23 Sep 2017 Location: Lancashire Posts: 545 ![]() ![]() |
Thanks Greg , reading through that it would appear that a 275 45 gives an almost identical sidewall to a 255 50 but are slightly wider. Sounds like they maybe what I'm after.
Hi Paul, haven't pulled the trigger yet. Tread getting down so need to do it soon.
That was my concern although I'm worried about ride quality rather than anything else.
I have 275's on mine (car came with them). Don't like them, but can only compare them with my 19" winter wheels which have a better ride and are quieter. The quality of the tyre also makes a difference and the 275's are cheap brand.
Kiwimac Member Since: 15 Jun 2018 Location: Wellington Posts: 48 ![]() ![]() ![]() |
Mine was delivered with 255 55 20 Goodyear Eagle F1 SUV's.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35648 ![]() ![]() |
indeed they will be slightly more comfortable but also the speedometer will be more true.. ... - .- -.
Just been having a look at mine and the 255 50's look awful close to the front struts.
Anyone any advice re the strut clearance before I take the plunge, |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3787 ![]() ![]() |
Yes 275/45/20 will be fine 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17 |
Woofster Member Since: 12 Jul 2018 Location: Toronto Posts: 121 ![]() ![]() |
P275/45R20 will be very, very close to OEM spec P255/50R20. Rolling circumference/diameter and sidewall thickness will only be slightly smaller.
Boxbrownie Member Since: 19 May 2018 Location: FF gone now....FL2 i6 to play with Posts: 245 ![]() ![]() ![]() |
If the owners manual quotes the standard tyres/wheels are suitable for snow chains then you have plenty of clearance for those tyres. Most like;y do anyway, but always good to check. David Please let me know if my comments upset you, I may wish to upset you again. |
